    PanelDue designations
    PanelDue
    579
    • Weevilundefined
      Weevil
      What is the difference between 7, 7i, and 7c?
        dc42 administrators @Weevil
        @Weevil 7 is for a 7" display with SSD1963 controller used with the separate PanelDue controller board. 7C is for a 7" display with a CPLD controller, used with the same PanelDue board. 7i is for the Integrated version, where the PanelDue electronics are on the same PCB as the display.
        Weevilundefined arhiundefined 2 Replies Last reply Reply Quote 0
        • Weevilundefined
          Weevil @dc42
          @dc42 Okay, thanks for clarifying. I wasn't sure which firmware update to use.
          • arhiundefined
            arhi @dc42
            @dc42 said in PanelDue designations:
            CPLD ? Is there a schematic available for this somewhere (super interested to see what you used CPLD for on paneldue) ? Thanks
              dc42 administrators @arhi
              @arhi there is or was a 7" display that used a CPLD chip instead of a conventional display controller. Here's an old listing for it: https://de.aliexpress.com/item/32640600970.html?gatewayAdapt=glo2deu.
              arhiundefined 1 Reply Last reply Reply Quote 0
              • arhiundefined
                arhi @dc42
                Interesting 🙂 This was designed by you/duet or was some off the market display? Never seen one of those, thanks for the info
                • T3P3Tonyundefined
                  T3P3Tony administrators @arhi
                  @arhi its an option for a display controller thats on the market. These chips sit between the PanelDue or other controller and the LCD screen itself.
                  www.duet3d.com
                  • arhiundefined
                    arhi @T3P3Tony
                    @T3P3Tony said in PanelDue designations:
                    cool, so duet has nothing to do with that design it's just a type of LCD .. clear
                    (I'm rather inexperienced with all the cpld/fpga stuff .. I learned it and do use them in my projects from time to time but even after years I'd not call myself even a junior in that field due to really low number of projects I used them in ... so wherever I see interesting application of them I try to get as much data as I can so I learn / gain some new ideas)
