How to read mainbord status on GPIO
  • undefined
    Rodrigue Richalland
    Hello everyone,
    I want to know if it's possible to read the mainbord status on GPIO pin ?
    I want to manage a RGB LED whith this variable.
    If somebody have already try to do it, i'm interrested.
    Thanks for your precious help😁
    undefined 1 Reply Last reply 2 Feb 2023, 22:49 Reply Quote 0
    • undefined
      OwenD @Rodrigue Richalland
      @Rodrigue-Richalland
      You need to monitor the object model and look at state.status
      The possible values are here
      https://github.com/Duet3D/RepRapFirmware/wiki/Object-Model-Documentation#statestatus
      Then you can use daemon.g to change the led.
      Something like this will update every 2 seconds
      while true
      if state.status = "idle"
      ; do code to set LED white
      elif state.status = "processing"
      ; do code to set LED green
      elif state.status = "halted"
      ; do code to make led red
      else
      ; do code to make led yellow for any other state
      G4 S2
      undefined 1 Reply Last reply 3 Feb 2023, 07:44 Reply Quote 2
      • undefined
        Rodrigue Richalland @OwenD
        @OwenD
        Thanks for you quick reply. I will try.
        1 out of 3
