Triple-z G32 true bed level question
After it does the initial height measure in the middle, it moves to the home corner (X0, Y0) and crashes. I have set correct Z-probe offset and bed size. Not sure how to correctly set M671.
M584 X0.1 Y0.0 E0.2 Z0.3:0.4:0.5 ; set drive mapping M671 X1:1:271 Y269:43:167 S50 ; set z drive coordinates
This how it set right and it crashes in the corner. I've entered the values in order from how the Z drivers are set up in M584.
@Velvia sys/bed.g file controls the bed levelling. M671 controls where the pivot point of the leadscrews are. See https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_auto_levelling
Please post your bed.g file, firmware version and hardware version.
@droftarts I completely forgot about bed.g
; bed.g ; called to perform automatic bed compensation via G32 ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Jul 16 2022 00:07:15 GMT+0200 (Central European Summer Time) M561 ; clear any bed transform. treat the bed as an ideal flat surface. ; Don't use parameter P of M558 here as it will reset probe offsets assigned in G31. M558 H20 F600 T12000 ; set a higher dive height H20 to prevent nozzle crash. G28 G30 P0 X3 Y10 Z-99999 G30 P1 X290 Y10 Z-99999 G30 P2 X157 Y280 Z-99999 S3 ; Don't use parameter P of M558 here as it will reset probe offsets assigned in G31. M558 H3 F600 T12000 ; set a low dive height H3 for faster mesh building. ; Mesh bed level M557 X5:300 Y35:300 S24
It's a mess from previous bed design. How would I set it up, is there a guide?
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.4.1 (2022-06-01 21:06:56) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: ZNGJJ-3196U-D65J0-40KML-2G03Z-R300P Used output buffers: 3 of 40 (28 max) === RTOS === Static ram: 103684 Dynamic ram: 110520 of which 56 recycled Never used RAM 24260, free system stack 132 words Tasks: NETWORK(ready,15.0%,184) HEAT(notifyWait,0.0%,338) Move(notifyWait,0.0%,265) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,356) CanClock(delaying,0.0%,337) TMC(notifyWait,1.2%,71) MAIN(running,82.7%,404) IDLE(ready,0.2%,29) AIN(delaying,0.8%,264), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 02:52:19 ago, cause: software Last software reset at 2023-02-08 14:26, reason: User, GCodes spinning, available RAM 27376, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 MCU revision 3, ADC conversions started 10340125, completed 10340124, timed out 0, errs 0 Step timer max interval 955 MCU temperature: min 27.4, current 27.5, max 27.5 Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/4/4, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 71, reads 603, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 2, read errors 0, write errors 0, ifcnt 71, reads 603, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 10, read errors 0, write errors 0, ifcnt 39, reads 602, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 67, reads 603, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 67, reads 603, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 5: standstill, SG min 2, read errors 0, write errors 0, ifcnt 67, reads 603, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 6: standstill, SG min 0, read errors 0, write errors 0, ifcnt 19, reads 602, writes 0, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2023-02-08 17:18:19 Cache data hit count 4294967295 Slowest loop: 11.62ms; fastest: 0.13ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 3.1ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 14, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 1198, completed 1198, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === CAN === Messages queued 60, received 0, lost 0, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 33/0/0 Tx timeouts 0,0,33,0,0,27 last cancelled message type 4514 dest 127 === Network === Slowest loop: 200.66ms; fastest: 0.06ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 1 WiFi firmware version 1.26 WiFi MAC address f0:08:d1:03:81:45 WiFi Vcc 3.44, reset reason Power up WiFi flash size 2097152, free heap 25200 WiFi IP address 10.0.0.30 WiFi signal strength -88dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
@Velvia When you say "it moves to the home corner (X0, Y0) and crashes" what actually crashes? Does it crash in X or Y, or is the nozzle too close to the bed already? I see you have G28 in bed.g. Does it lift Z at the end? Post your homeall.g as well.
@droftarts XY crashes, Z is fine I think. I reset the printer before anything else happens.
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Jul 16 2022 00:07:15 GMT+0200 (Central European Summer Time) G91 ; relative positioning G1 H2 Z5 F1000 ; lift Z relative to current position G1 H1 Y-350 F2500 ; move quickly to Y axis endstop and stop there (first pass) G1 Y5 F4000 ; go back a few mm G1 H1 Y-5 F200 ; move slowly to Y axis endstop once more (second pass) G1 Y1 ; move to Y1 for space G1 H1 X-350 F2500 ; home X axis (first pass) G1 X5 F1000 ; go back a few mm G1 H1 X-5 F500 ; move slowly to X axis endstop once more (second pass) G1 X1 ; move to X0.5 for space G90 ; absolute positioning G1 X150 Y150 F6000 ; go to first bed probe point and home Z G30 ; home Z by probing the bed G1 H2 Z2 ; move Z down 2mm G1 X1 Y1 F6000 ; move to the back
Post your full config.g please.
; Configuration file for Duet 3 Mini 5+ (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Jul 16 2022 00:07:15 GMT+0200 (Central European Summer Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"SK-Go2" ; set printer name M669 K1 ; select CoreXY mode ;M918 P1 E4 F2000000 ; configure direct-connect display ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S1 D2 ; XY 1 physical drive 0.0 goes forwards M569 P0.1 S0 D2 ; XY 2 physical drive 0.1 goes backwards M569 P0.2 S1 D2 ; E physical drive 0.2 goes forwards M569 P0.3 S0 ; Z 1 physical drive 0.3 goes backwards M569 P0.4 S0 ; Z 2 physical drive 0.3 goes backwards M569 P0.5 S1 ; Z 3 physical drive 0.3 goes forwards M584 X0.1 Y0.0 E0.2 Z0.3:0.4:0.5 ; set drive mapping M671 X1:1:271 Y269:43:167 S50 ; set z drive coordinates M350 X32 Y32 Z16:16:16 E16 I1 ; configure microstepping with interpolation M92 X400 Y400 Z800.00 E420.00 ; set steps per mm M566 X900.00 Y900.00 Z400.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X7500.00 Y7500.00 Z1000.00 E1200.00 ; set maximum speeds (mm/min) M201 X5000.00 Y5000.00 Z500.00 E250.00 ; set accelerations (mm/s^2) M906 X1400 Y1400 Z900 E800 I10 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minimum M208 X299 Y318 Z300 S0 ; set axis maximum ; TMC Trinamic Drive Tuning ; Tune tpwmthrs (V) so stealthchop runs at appropriate speeds ; and tune thigh (H) to avoid shifting into fullstep mode ; Tune stealthchop to 250mm/s, set coolstep to the same, and then limit the max speed to 120mm/s ; tpwmthrs = 12000000 / (<speed in mm/s> * 200 * 16) ; This keeps everything slow and quiet. ; Endstops M574 X1 S1 P"io5.in" ; configure active-high endstop for low end on X via pin "io5.in" M574 Y1 S1 P"io6.in" ; configure active-high endstop for low end on Y via pin "io6.in" ;M574 Z1 S2 P"io3.in" ; done under Z-probe instead ;M574 X1 S1 ; configure sensorless endstop for low end on X ;M574 Y1 S1 ; configure sensorless endstop for low end on Y ;M915 X S30 H140 R0 ; sensitivity of X and Y sensorless homing, R2 = pause print ;M915 Y S20 H140 R0 ; sensitivity of X and Y sensorless homing, R2 = pause print ; Z-Probe M574 Z1 S2 P"io3.in" ; configure Z-probe endstop for low end on Z M558 P5 C"io3.in" I1 H1 F4000:1000 T10000 A5 S0.03 ; set Z probe type as filtered digital (P5), dive height to 1 (H1), probe 5 times (A5), feedrate 3000 (F), Travel speed to and between probe points (mm/min (T10000)), mulitple probing tolerance (S) G31 P500 X21 Y10 Z1.50 ; set Z probe trigger value, offset and trigger height M557 X5:290 Y5:290 S40 ; define mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out0 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"temp1" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin temp1 M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S300 ; set temperature limit for heater 1 to 300C ; Fans M950 F1 C"out6" ; create fan 1 on pin out6 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on M308 S10 Y"mcu-temp" A"MCU" ; MCU temp on temp sensor 10 M950 F0 C"out5" ; create fan 1 on pin out6 and set its frequency M106 P0 S0.5 H10 T30 ; set fan 1 value. Virtual thermostatic control is turned on M912 P0 S-1.2 ; MCU temperature calibration ; Tools M563 P0 S"Volcano" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss T0 ; select first tool
@Velvia said in Triple-z G32 true bed level question:
G30 P2 X157 Y280 Z-99999 S3I think you just need to adjust your probe points.
I would suggest you manually jog your print head to place the probe where you want it and then note the current XY position and use that.
M558 P5 C"io3.in"This is also wrong. You can't use the pin name twice. Luckily for you Z1 S2 doesn't even take a pin name. I would suggest you just remove that M574 Z1 S2 line entirely as it's not needed at all.
@Phaedrux Thank you!! I'm now on the right track, just need to fine tune it.
