Duet 2 WiFi M564 Issue
On my printer using a the Duet WiFi board when I run M564 H0 it seems to process fine but it does not activate to move while not homed as the Dashboard does not activate for X Y Z moves. Any reason why this is happening? I included M122 and config.g files in case they might help. Thanks
Update your firmware and see if the behaviour is the same. Upload this zip file to the system tab in DWC.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zip
Thanks that solved the problem!
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
