    [3.5.0-b2] Thumbnail Loading Issues
    Beta Firmware
    • CCS86undefined
      CCS86
      I'm having some issues with thumbnail loading.
      Thumbnails in the root gcode directory seem to load quite quickly, while jobs in a subdirectory load very slowly. I'm not sure if the root directory files are simply having thumbnails cached, and the subdirectory files are not. Or, if something else is going on.
      Also, while waiting for the thumbnails to load in a subdirectory, if you delete a job file, thumbnails which are already loaded disappear and DWC stops loading thumbnails altogether.
      Here is a video showing this:
      https://imgur.com/MaOBiXq
      CCS86undefined chrishammundefined 2 Replies Last reply Reply Quote 0
      • CCS86undefined
        CCS86 @CCS86
        After waiting quite some time for the subdirectory to load all thumbnails, they now display quickly when re-entering the subdirectory. So, it seems like the caching is an "all or nothing" situation right now, instead of being individually cached.
        • CCS86undefined
          CCS86
          After refreshing the DWC page, the main directory thumbnails appear almost instantly (pulled from cache). But, the subdirectory repeats the slow loading process. So, it appears that the subdirectory thumbnail cache isn't being written to local storage, like the main directory is.
          • CCS86undefined
            CCS86
            Bump....
            • T3P3Tonyundefined
              T3P3Tony administrators
              @CCS86 are you using stand alone or SBC mode?
              It may just be that I don't have a sub directory with quite as many images in it but i cant reproduce this:
              @CCS86 said in [3.5.0-b2] Thumbnail Loading Issues:
              Exiting and reentering a sub directory with only part of the thumbnails cached does not restart the thumbnail downloads for existing thumbnails as far as i can see. Those downloaded appear to be cached (this in Chrome, on windows), here you can see the first 10 files in the subdirectory are laoded from cache, and then the download of the remainder resumes.
              Yes confirmed this issue, @chrishamm here is the chrome console report:
              Exiting the sub directory and re-entering it kicks the thumbnail download process off again.
              www.duet3d.com
              CCS86undefined 1 Reply Last reply Reply Quote 0
              • chrishammundefined
                chrishamm administrators @CCS86
                @CCS86 Thanks, I can confirm this problem as well. In addition to the file delete bug, it turns out that pressing "Refresh" in the root directory deletes all the cached thumbnails of G-code files in subdirectories but I've got a fix ready for this, too.
                Duet software engineer
                • CCS86undefined
                  CCS86 @T3P3Tony
                  Thanks guys. Looking forward to the next version.
                  @T3P3Tony I am running in standalone mode. Browser is Chrome in Win10 x64.
                  Let me know if you need any more information or testing.
