    Duet2 RRF3.x no basic machine setup possible
    Using Duet Controllers
    • SetraXundefined
      SetraX
      I bought Duet 2 Ethernet before Wifi was available many years ago. I ran 1.xx on it for a long time. Then life got difficult and it sat in my basement for many years. Last year in summer I upgraded to 3.xx which was not easy at all but I got it on the machine. Since then I was unable to configure and always have network errors or disconnection issues.
      This is very difficult since anytime you edit a file on the webinterface everything is gone - sooo time consuming.
      Yesterday I started again in hope that time would have solved many issues but I got struck by reality again, so I upgraded to 3.4.5, which actually stuck at the very end (maybe the cause of a network disconnect)... anyway I had to do it 3 times until it worked fully through all the files and I was able to click the Update the uploaded files. Anyways it succeeded then flawlessly.
      Did a clean config.g
      Setup everything hardware, BL-Touch, Heaters, Extruder and Motors, but that did not brought me forward a single inch...
      BTW, I operate/pet a TEVO Little Monster (Delta), which I upgraded with stronger belts, a new BLTOUCH, new gears etc. so hardware is basically new and printed only a couple of boats... thats it.
      Why I do have so many Issues? I don't know, but I noticed the following:
      When I do Home all axis, there is no effect on the Status of the machine. It depends where the head is located relative to the machine.
      I. As I set the height at 520, and the head went down to the bed by gravity. It happily adds 520 to the way the head moves up to the homing switches. Then the machine reports X, Y, Z status added to the way it had to move up. As you can imagine the values are different all the time.
      II. I have a M501 at the end of the config.g file which does not affect anything, except I delete config-override.g, then it complains, but if it is there it is not loaded. I have to do a manual M501 in order to load the config-override.g settings. only then the machine starts to update the status settings.
      In the meantime my bed looks like the moon surface since the head with the probe crushed so many times the bed that I actually thought about throwing the machine into the bin.
      This is my last attempt to find a way to make 3D printing happen, since I can not go back to 1.02... also my paneldue 1.22(b28) is also reporting all kind of errors which I can not even find somewhere...
      for instance, heater 0 not found and so on.
      I have no Idea what else I could do... and I'm open to any leads or ideas
      All the best
      oliofundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • oliofundefined
        oliof @SetraX
        @SetraX at a hazard, I would suggest to replace the sd card with a new one. Possible configuration issues are easier to determine if we can see your config.g
        SetraXundefined 1 Reply Last reply Reply Quote 0
          Phaedrux Moderator @SetraX
          @SetraX said in Duet2 RRF3.x no basic machine setup possible:
          I upgraded to 3.4.5
          Did you also update the DWC files in the WWW folder on the SD card?
          my paneldue
          Have you updated the Paneldue firmware to 3.4.x latest? Is it enabled in config.g?
          Can you share that?
          Also please send M122 and M98 P"config.g" and copy and paste the results.
          • SetraXundefined
            SetraX @oliof
            @oliof I really thought about that... but makes no sense does it? I tell you why. Yesterday my desktop computer died and believe it or not, I took my new laptop and connected via wifi to my router at home and no disconnect issues anymore.
            This leads me to the following. The network card must have had a glitch or the port on the switch which my desktop was connected. Strange thing about is that no other connection was showing problems, only those to the printer. I also connected via a desktop switch... no difference.
            Anyways thanks for the engagement. I was so suprised that for such a long time it must have had to sit and wait and all of a sudden a major problem solved, without DUET2 interaction.
            All the best
            • SetraXundefined
              SetraX @Phaedrux
              @Phaedrux
              M122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet Ethernet 1.02 or later
              Board ID: 08DDM-9FAM2-LW4SD-6J9F4-3SN6M-92ZVY
              Used output buffers: 3 of 24 (12 max)
              Static ram: 23876
              Dynamic ram: 70408 of which 0 recycled
              Never used RAM 20132, free system stack 122 words
              Tasks: NETWORK(ready,28.0%,237) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,311) MAIN(running,71.7%,445) IDLE(ready,0.1%,29), total 100.0%
              Owned mutexes:
              Last reset 00:09:47 ago, cause: power up
              Last software reset at 2023-02-13 14:38, reason: User, GCodes spinning, available RAM 20132, slot 2
              Error status: 0x00
              Aux0 errors 0,0,0
              Step timer max interval 0
              MCU temperature: min 17.4, current 27.9, max 28.3
              Supply voltage: min 24.0, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
              Driver 0: position 132587, standstill, SG min/max 0/289
              Driver 1: position 132587, standstill, SG min/max 0/291
              Driver 2: position 132587, standstill, SG min/max 0/282
              Driver 5: position 0
              Driver 6: position 0
              Driver 7: position 0
              Driver 8: position 0
              Driver 9: position 0
              Driver 10: position 0
              Driver 11: position 0
              Date/time: 2023-02-13 18:05:45
              Slowest loop: 6.22ms; fastest: 0.17ms
              === Storage ===
              Free file entries: 10
              SD card longest read time 2.8ms, write time 0.0ms, max retries 0
              DMs created 83, maxWait 410ms, bed compensation in use: none, comp offset 0.000
              === MainDDARing ===
              Scheduled moves 11, completed moves 11, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
              === AuxDDARing ===
              Segments left: 0
              Movement lock held by null
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              Daemon is idle in state(s) 0
              Code queue is empty.
              === Network ===
              Slowest loop: 8.25ms; fastest: 0.02ms
              HTTP sessions: 1 of 8
              Interface state active, link 100Mbps full duplex
              OK, I answered to oliof just before that the network problem dissolved.... wrong. After issuing the response for M122 the network disconnect popped up on the right lower screen, it seems to be faster reconnected on a newer computer though...
              DWC files... i did not intentionally, so how do I do it. yesterday I downgraded to 3.3.
              Paneldue ... no since it says it only has about 29kb memory and as far as I read it, it is impossible to run
              a newer firmware as 1.22 on it anyways...Am I wrong?
              Config.g comes here....
              ; Configuration file for testing Duet Ethernet and Wifi
              M550 P"Monstaprint" ; Machine name and Netbios name (can be anything you like)
              M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
              M586 P0 S1 R80 ; enable HTTP on Port80
              ;M665 L397.190:397.190:397.190 R175.000 H537.500
              M665 R170 L397.19 B155 H525 ; set delta radius, diagonal rod length, printable radius and homed height
              M666 X0 Y0 Z0 ; put your endstop adjustments here
              M569 P0 S1 ; Drive 0 (X) goes forwards
              M569 P1 S1 ; Drive 1 (Y) goes forwards
              M569 P2 S1 ; Drive 2 (Z) goes forwards
              M569 P3 S1 ; Drive 3 (E0) goes forwards
              M584 X0 Y1 Z2 E3 ; X on motor0, Y on motor1, Z on motor2, E0 on motor4
              M350 E128 I0 ; Configure microstepping without interpolation
              M350 X64 Y64 Z64 I1 ; Configure microstepping with interpolation
              M92 X320 Y320 Z320 E1100 ; Set steps per mm
              M566 X1200 Y1200 Z1200 E2500 ; Set maximum instantaneous speed changes (mm/min)
              M203 X10000 Y10000 Z10000 E3000 ; Set maximum speeds (mm/min)
              M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
              M906 X1600 Y1600 Z1600 E1250 I50 ; Set motor currents (mA) and motor idle factor in per cent
              M574 X1 S1 P"xstop" ; X min active high endstop switch
              M574 Y1 S1 P"ystop" ; Y min active high endstop switch
              M574 Z1 S1 P"zstop" ; Z min active high endstop switch
              ; Z-Probe - BLTouch
              M950 H7 C"nil" ; Disable heaters h7 to free up pins
              M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
              M558 P9 C"^zprobe.in" H5 K0 F1500:150 T5000 ; set Z probe type to bltouch and the dive height + speeds
              G31 X0 Y20 Z2.70 P50 K0; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
              ; Z-Probe - Nozzle
              M558 P5 C"!e1stop" H10 K1 F1000:100 T2500 ; set Z probe type to bltouch and the dive height + speeds
              G31 X0 Y0 Z0.1 P50 K1 ; Z probe trigger value, offset in relation to nozzle. And trigger height adjustment
              M557 R150 S15 ; Define mesh grid ;
              ; Bedheater
              M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning) - old allowed to stay
              M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; sensor 0 ### R4700
              M950 H0 C"bedheat" T0 ; create bed heater and map sensor 0
              M140 H0 ; the bed heater is heater 0
              M140 S65 R0 ; set bed temperature to 65C and bed standby temperature to 20C
              M144 S0 ; activate standby temperature
              ;Hotend
              M308 S1 P"e0temp" Y"thermistor" T100000 B4607 C8.950070e-8 R4700 ; sensor 1
              M950 H1 C"e0heat" T1 ; create heater and map sensor 1; Tools
              M143 H1 P0 S280 A2 ; switch off heater 1 temporarily if it exceeds 280°C
              M143 H1 P1 S290 A0 ; raise a heater fault if it exceeds 290°C
              ; Fan Modes
              M950 F0 C"fan0" ; Fan 0 definition
              M950 F1 C"fan1" ; Fan 1 definition
              M106 P0 T40 H1 ; Turn on Fan0 if Heater Temperature is above 40°C
              M106 P1 S0 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
              M563 P0 D0 H1 F0 S"Extruder" ; define tool 0
              G10 P0 R120 S0 ; set initial tool 0 active and standby temperatures to 120C
              M501
              M280 P0 S160 I1 ; Alarm Release and Push-Pin UP
              G28
              My M501 seems to work now... why don't know.
              I tried to setup a second probe since the offset was to high and I can not make it work with BLTouch, since it is 20mm from the nozzle so I tried to go with some supermicro aliexpress tactile switch which I have to stick on the tip of the nozzle...
              Bad thing about it ... can't get it configured as Probe ONE, always reads zero. I connected it to E1Stop and GND on DUET2... G31 K1 always reads 0, as K0 BLTOUCH reads 1000 when I activate it....
              Is there something else to do?
              Thank you so much for engagement, I feel now I'm not alone anymore.
              BTW I figured out a Workaround for my Homeing Zero Problem.
              1. After Homing... all Axes did not Zero so I put a M92 X0Y0 and magically it zeroed....
              2. Relative move down to test BED with BLTOUCH.
              3. BLTOUCH updated correct 0(at least in the middle) so I do not crush the BED anymore..
              Don't know how you do it but my homeing looks like that:
              ; Use relative positioning
              G91
              ; Move all towers to the high end stopping at the endstops (first pass)
              G1 H1 X750 Y750 Z750 F3500
              ; Go down a few mm
              G1 H2 X-5 Y-5 Z-5 F2500
              ; Move all towers up once more (second pass)
              G1 H1 X50 Y50 Z50 F500
              ; Go down a few mm
              G1 H2 X-2.5 Y-2.5 Z-2.5 F2500
              ; Move all towers up once more (third pass)
              G1 H1 X50 Y50 Z50 F100
              G92 X0Y0
              ; Move down a few mm so that the nozzle can be centred
              ;G1 X-25 Y-25 Z-25 F5000 H2
              ;G1 X50 Y50 Z50 F1000 H3
              ; Reset BL-Touch
              M280 P0 S160 I1 ; Clear any Alarms of BLTOUCH
              M280 P0 S90 I1 ; Pen up
              G1 X0 Y-20 Z-500 F10000
              ; Switch back to absolute positioning and go to the centre
              G90
              Over and out ... waiting for feedback
                I would suggest that you upgrade to 3.4.5 by uploading the full zip file release to the system tab in DWC.
                https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zip
                That will update everything including DWC.
                After updating the firmware can you send M98 P"config.g" to check for any syntax errors?
                For the PanelDue, what hardware version is it specifically? I have an old v2 panel and it still runs 3.4.x so unless you have a really ancient one I think you would be ok.
                I would simplify those to be M552 S1 and M586 P0 S1 since you're just listing the default values anyway.
                ; Z-Probe - BLTouch
                It's not necessary to use "nil" to free up a pin unless it's already been assigned previously. At startup, it won't have been bound to anything yet.
                If this is a delta, your endstop configuration is incorrect.
                You have them set as low end stops. But on a delta they are at the top.
                X1 Y1 Z1 should be X2 Y2 Z2
                Fixing that should negate the need to do a weird workaround.
