    No DWC from Ethernet Duet on home wifi
    • djthumaundefined
      djthuma
      I am working with a couple boards, a duet 2 ethernet and duet 3 6XD.
      I can get connected to the ethernet motherboards via YAT.
      I have the motherboard plugged into an ethernet switch, which has my wifi ethernet input, PC network output and the duet ethernet connected.
      When I run M552 it says a network is established. But I cannot find it on the network via command network search or wed searching the DWC I.P.
      Is this the right setup for the network? Can I plug the ethernet directly into my computer?
        Phaedrux Moderator @djthuma
        @djthuma said in No DWC from Ethernet Duet on home wifi:
        Yes you can, see here: https://docs.duet3d.com/User_manual/Machine_configuration/Networking#wired-direct-connection
        Sounds like you might be missing something.
        djthumaundefined 1 Reply Last reply Reply Quote 0
        • djthumaundefined
          djthuma @Phaedrux
          Thank you @Phaedrux
          It was my duet 3 and duet 2 's default gateway that was not set to the network gateway!
          Not sure if the windows command should be included in the getting connected section.
          But I did need to use Command Prompt -> ipconfig/all command to identify the correct network subnet and default gateway.
          Thanks again
