    Transistor TR6 Duet 3 wifi
    • koreandiundefined
      koreandi
      Dear DUET-users,
      I blew up my temp-controll for FAN out 5/6 by using the wrong voltage. The FAN runs permanently now and the temp-controll does not work anymore. 24V are still applied.
      I can see clearly that the Transistor TR6 with the component-label LSDL 1K is blown. I would like to change it to see if that fixes my problem.
      A spare DUET Board is already on the way but I wanna give it a try.
      Does anybody know what component that exactly is?
      My Board is DUET 3 Mini 5+ V1.01.
      Thank a lot in advance.
      moth4017undefined dc42undefined 2 Replies Last reply Reply Quote 0
      • moth4017undefined
        moth4017 @koreandi
        @koreandi
        TR6 is a BUK9880-55A on v0.5
        ver 1 different see link
        https://github.com/Duet3D/Duet3-Mini5plus/blob/main/v1.0/Duet3_5%2B_Ethernet_Schematic_v1.0.pdf
        koreandiundefined 1 Reply Last reply Reply Quote 0
        • koreandiundefined
          koreandi @moth4017
          @moth4017
          Thanks a lot. Is there any electrical schematic availiable?
          After a quick research the named component has 4 legs (3+1) But the component on my board only has 3 legs (2+1).
          BOARD:
          BUK9880-55A:
          moth4017undefined 1 Reply Last reply Reply Quote 0
          • moth4017undefined
            moth4017 @koreandi
            @koreandi
            v1 here
              dc42 administrators @koreandi
              @koreandi for the correct part number see https://docs.duet3d.com/en/User_manual/Troubleshooting/Parts#fan-mosfet.
              • koreandiundefined
                koreandi @dc42
                Just a quick reply...
                I replaced the mosfet with:
                AOSS32334C
                It was a little challenging to solder but I could replace the part and the board just works fine again.
                Thanks for the support.
