    Been fighting with print adhesion and mesh bed compensation.
    • cdsmith12undefined
      cdsmith12
      My printer prints really good, but I can’t get a print to stay on to save my life.
      Many of you that have been around a while will remember the Vulcanus 40 COREXY, 440mm x 440mm x 400mm, this is what I built in the beginning. I got frustrated, pushed it to the side and left it for 3 years. Then when the Hemera came out a couple years ago I decided I was going to completely revamp it. I changed the electronics to a Duet 2 Wi-Fi, E3d Hemera, and BlTouch. I replaced all of the linear rods, with linear rails, and no I am not having any issues with the 4 vertical linear rails. If I take the 2 Z motor threaded rods out I can slide it up and down with no resistance. I put a WhamBam flex plate on my 8mm cast aluminum bed.
      What I have noticed recently is that when it lays down the second layer I can hear it dragging across that first layer in certain places which leads me to think that it is not loading my Mesh compensation correctly. Also I have never enclosed it, but intend to do so soon.
      I use Duet Web Control, Reprapfirmware, and PrusaSlicer
      I have other printers, but I really want to get this large format printer that I have sunk a crap load of money into with 3 different sets of electronics, and 3 different extruders to work. Thanks for any assistance.
      Prussa slicer Startup Gcode
      M104 S[first_layer_temperature] ; set extruder temp
      M140 S[first_layer_bed_temperature] ; set bed temp
      M190 S[first_layer_bed_temperature] ; wait for bed temp
      M109 S[first_layer_temperature] ; wait for extruder temp
      G28 XY ;Home XY
      M561 ; Clear any bed transform that might be in place
      G1 X203 Y208 ; Move Probe to middle of bed
      G30 ; Do a single probe
      M375 P"WhamBam.csv" ; Load my custom heightmap. Otherwise use G29 S1
      G1 Z20.0 F6000 ; Move Z to 10
      G1 X5 Y5 ; Move head to front left
      G92 E0.0 ; reset extruder position
      G1 Z0.2
      G1 X60.0 E9.0 F1000.0 ; intro line
      G1 X100.0 E12.5 F1000.0 ; intro line
      Config.g
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jun 14 2020 23:31:14 GMT-0500 (Central Daylight Time)
      M550 P"The Plastic Beast" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes forwards
      M569 P1 S0 ; physical drive 1 goes forwards
      M92 X80.00 Y80.00 Z810.00 E420.00 ; set steps per mm
      M566 X1000.00 Y1000.00 Z100.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X24000.00 Y24000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
      M906 X1400 Y1400 Z1400 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X399 Y410 Z400 S0 ; set axis maxima
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M558 P9 C"^zprobe.in" H5 F100 T4000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-26 Y1.7 Z0.96 ; set Z probe trigger value, offset and trigger height
      M557 X5:365 Y30:390 S20 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S285 ; set temperature limit for heater 1 to 285C
      M106 P0 S0 H1 T45 ; set fan 0 value. Thermostatic control is turned on
      M912 P0 S1 ; set cpu temp offset
      M501
      ; config-override.g file generated in response to M500 at 2023-02-09 21:29
      ; Heater model parameters
      M307 H0 R0.223 K0.166:0.000 D3.49 E1.35 S1.00 B0
      M307 H1 R1.942 K0.534:0.000 D5.82 E1.00 S1.00 B0 V12.1
      ; Workplace coordinates
      G10 L2 P1 X0.00 Y0.00 Z0.00
      G10 L2 P2 X0.00 Y0.00 Z0.00
      G10 L2 P3 X0.00 Y0.00 Z0.00
      G10 L2 P4 X0.00 Y0.00 Z0.00
      G10 L2 P5 X0.00 Y0.00 Z0.00
      G10 L2 P6 X0.00 Y0.00 Z0.00
      G10 L2 P7 X0.00 Y0.00 Z0.00
      G10 L2 P8 X0.00 Y0.00 Z0.00
      G10 L2 P9 X0.00 Y0.00 Z0.00
      ; homeall.g
      ; called to home all axes
      G91 ; relative positioning
      G1 H1 X-405 Y-405 F1800 ; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 X-405 ; home X axis
      G1 H1 Y-405 ; home Y axis
      G1 X5 Y5 F6000 ; go back a few mm
      G1 H1 X-405 F360 ; move slowly to X axis endstop once more (second pass)
      G1 H1 Y-405 ; then move slowly to Y axis endstop
      G90 ; absolute positioning
      G1 X31 Y5 F6000 ; go to first bed probe point and home Z
      ;G91 ; relative positioning
      ;G1 Z5 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
      ; homez.g
      ; called to home the Z axis
      G1 X41 Y15 F6000 ; go to first probe point
      • T3P3Tonyundefined
        T3P3Tony administrators @cdsmith12
        @cdsmith12 can you show us what the heightmap looks like using the heighmap plugin in DWC?
        also you can confirm its being loaded in the DWC Dashboard but looking at the "compensation in use:" field under "Compensation and Calibration"
        www.duet3d.com
        cdsmith12undefined 1 Reply Last reply Reply Quote 0
          cdsmith12 @T3P3Tony
          Under the "Compensation in use" it says "none", so I guess I need to figure out where my code is wrong. I'm also going to adjust the one corner just a hair to try to get it all green, and rerun mesh compensation.
          • A Former User?
            A Former User @cdsmith12
            @cdsmith12 I think the reason you see "None" for "Compensation in use" in DWC is because the only place you have the height map loaded is in your print start code
            it should load once you start a print.
            Also, if youre interested in expediting your probing by only probing print areas, I would suggest you take a look at this thread:
            https://forum.duet3d.com/topic/30796/only-probe-where-the-part-will-be-printed?_=1676405937900
              cdsmith12 @A Former User
              @wwak84 So I figured out that it was loading, but not in time to edit before you posted. Here is the top and bottom of a print I started. I think I got my z offset better, but something is causing this ripple effect and the higher it gets the more it drags, then ultimately knocks the print off. These were today with the height map posted above. IMG_4435.jpg IMG_4434.jpg This is the print before I made this post and it is 390mm long, if you look closely it knocked it loose at about 3mm thick and then continued to print, but it has this weird wavy look, but the side view of the layers looks pretty good. IMG_4437.jpg IMG_4436.jpg
                cdsmith12 @cdsmith12
                @cdsmith12 Sorry for the jumbled words, the preview didn't look like that.
                • A Former User?
                  @cdsmith12 I think the nozzle may be a bit too close still.
                  Its hard to troubleshoot without knowing what else you've tried and other details, but I will make a few other guesses that hopefully are helpful. These are some of the issues that I ran into with rough first layers
                  Calibrate extruder steps. If you've been using your printer fine and this is a recently developed issue then calibration doesn't seem like a probable cause but never hurts to double check.
                  Is your nozzle well used? It may have worn to a larger diameter and now adjacent lines overlap too much.
                  Does different filament cause the same issue? I had similar problems with some random amazon brand PLA and it turned out the filament had inconsistent diameter.
                  Old filament that has absorbed moisture? The excess moisture could be contributing to roughness
                  Hopefully I havent stated the obvious here
