    Homing issues setting up CR-10S S4
    • GBusy24undefined
      GBusy24
      I've been running a Duet Wifi in my custom CoreXY for going on 7 years now. Love it and that's why I've decided to drop one in my CR-10S S4. Having major issues trying to get it to home. I'm using the original 2 wire endstops and have them wired to the outer pins. They show the proper states when sending M119. I'll cut to the chase and show all my info in hopes someone will tell me what I'm doing wrong. RRF 3.4.5 and latest DWC. X endstop is low end. Y endstop is high end. BLTouch for Z..................;
      Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon Jan 24 2022 20:50:56 GMT-0500 (Eastern Standard Time)
      M550 P"CR-10S S4" ; set printer name
      M564 H0 ; move axes W/O homing
      M575 P1 B57600 S1 ; set baudrate
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes forwards
      M569 P1 S0 ; physical drive 1 goes forwards
      M92 X80.00 Y80.00 Z400.00 E869 ; set steps per mm
      M566 X600.00 Y600.00 Z30.00 E20.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z900.00 E1200.00 ; set maximum speeds (mm/min)
      M906 X800 Y900 Z900 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X400 Y400 Z350 S0 ; set axis maxima
      M574 X1 S0 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y2 S0 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
      ;M574 X1 Y2 S1 ; X home to min. Y home to max. Normally Closed limit switches.
      M574 Z1 S2 ; Define Z to use Probe. Home to Min
      M558 P9 C"^zprobe.in" H5 F120 T6000
      G31 P500 X-41.8 Y32.2 Z2.1
      M557 X0:340 Y0:350 S50 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
      M307 H0 R0.977 K0.312:0.000 D2.76 E1.35 S1.00 B0 ; disable bang-bang mode for the bed heater and set PWM limit
      M106 P0 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
      M106 P1 S1 H1 T45 ; set fan 0 value. Thermostatic control is turned on
      M501
      HOMEALL:
      ; called to home all axes
      G91 ; relative positioning
      G1 H2 Z4 F600 ; lift Z relative to current position
      G1 H1 X-410 Y410 F3000 ; move quickly to X or Y endstop and stop there (first pass)
      G1 H1 X-410 ; home X axis
      G1 H1 Y410 ; home Y axis
      G1 X5 Y-5 F6000 ; go back a few mm
      G1 H1 X-410 F360 ; move slowly to X axis endstop once more (second pass)
      G1 H1 Y410 ; then move slowly to Y axis endstop
      G90
      G1 X200 Y200 F6000
      G30
      ;G91 ; relative positioning
      ;G1 Z5 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
      HOMEX:
      ; called to home the X axis
      G1 H1 X-41O F3000 ; move quickly to X axis endstop and stop there (first pass)
      G1 X5 F6000 ; go back a few mm
      G1 H2 Z-5 F6000 ; lower Z again
      HOMEY:
      G91 ; relative mode
      G1 H2 Z4 F200 ; raise head to avoid dragging nozzle over the bed
      G1 H1 Y410 F3000 ; move up to 410mm in the Y direction, stopping if the homing switch is triggered
      G1 Y-4 F600 ; move slowly 4mm in the -Y direction
      G1 S1 Y10 ; move slowly 10mm in the Y direction, stopping at the homing switch
      G1 S2 Z-4 F200 ; lower the head again
      G90 ; back to absolute mode
      HOMEZ:
      ; homez.g
      ; called to home the Z axis
      G1 H2 Z4 F200 ; raise head 4mm to ensure it is above the Z probe trigger height
      G1 X200 Y200 F2000 ; put head over the centre of the bed, or wherever you want to probe
      G30 ; lower head, stop when probe triggered and set Z to trigger height
      M122:
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet WiFi 1.02 or later
      Board ID: 0JD0M-9P6M2-NW4SN-6JKD2-3S46L-9VS3M
      Used output buffers: 2 of 26 (23 max)
      Static ram: 23836
      Dynamic ram: 75032 of which 0 recycled
      Never used RAM 13140, free system stack 152 words
      Tasks: NETWORK(notifyWait,13.9%,237) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,314) MAIN(running,86.0%,442) IDLE(ready,0.0%,30), total 100.0%
      Owned mutexes:
      Last reset 00:31:57 ago, cause: software
      Last software reset at 2023-02-21 20:22, reason: User, GCodes spinning, available RAM 12972, slot 0
      Error status: 0x00
      Aux0 errors 0,0,263
      Step timer max interval 0
      MCU temperature: min 39.4, current 40.0, max 40.6
      Supply voltage: min 24.1, current 24.4, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min n/a
      Driver 1: standstill, SG min n/a
      Driver 2: standstill, SG min n/a
      Driver 3: standstill, SG min n/a
      Driver 4: standstill, SG min n/a
      Driver 5:
      Driver 6:
      Driver 7:
      Driver 8:
      Driver 9:
      Driver 10:
      Driver 11:
      Date/time: 2023-02-21 20:54:55
      Slowest loop: 9.64ms; fastest: 0.18ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 1.4ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 3, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 1, completed 1, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty
      === Network ===
      Slowest loop: 101.93ms; fastest: 0.07ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      = WiFi =
      Network state is active
      Failed messages: pending 0, notready 0, noresp 2
      WiFi firmware version 1.27
      WiFi MAC address 84:0d:8e:b3:b4:95
      WiFi Vcc 3.40, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 23824
      WiFi IP address 192.168.0.27
      WiFi signal strength -68dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      Thanks!
      No such thing as spare time. No such thing as free time No such thing as down time. All you got is lifetime. Go!
        Phaedrux Moderator @GBusy24
        @GBusy24 said in Homing issues setting up CR-10S S4:
        Are you sure about that? If the endstop is at the rear for the bed, the nozzle is actually at the front and low end when homed.
        Y- should move the nozzle to the front of the bed, Y+ to the back.
        GBusy24undefined 2 Replies Last reply Reply Quote 0
        • GBusy24undefined
          GBusy24 @Phaedrux
          @Phaedrux Thanks. I will change Y endstop to low-end then and see what I get
          • GBusy24undefined
            GBusy24 @Phaedrux
            @Phaedrux, I've changed the Y homing to low end, but now my endstops show triggered when they're not. I've researched and really haven't found an answer. As stated I have the 2 wire endstops. should I flip the wires on the pins?
              Show me your current config.
              To change the trigger state you either add or remove a ! to the pin name for the endstop. So unless you changed that in the config I suspect a wiring issue?
              Did you physically move the endstop, or change the config?
              GBusy24undefined 1 Reply Last reply Reply Quote 0
              • GBusy24undefined
                GBusy24 @Phaedrux
                @Phaedrux, that's what I was looking for. The reference to the '!'. I had forgotten about it. Thank you kindly.
