Changed ISP
@Phaedrux said in Changed ISP:
Does it still think it's in SBC mode?
No. It just all of a sudden worked on my network on the new static ip address I'd given it 192.168.0.xxx (on Now Broadband).
Before I was with Talktalk Broadband on 192.168.1.xxx, but when I changed ISP if I typed in my browser the duets static ip address it couldn't be found. Angry ip scanner couldn't find it. I had no network leds illuminated on the ethernet connector.
Here's the result from M122 in DWC using my browser on the new static ip address;27/02/2023, 10:45:44 M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.4.4 (2022-10-20 16:19:01) running on Duet 3 MB6HC v1.01 (standalone mode) Board ID: 0JD2M-999AL-D25SW-6J9D0-3SD6M-9PY70 Used output buffers: 8 of 40 (20 max) === RTOS === Static ram: 152824 Dynamic ram: 97204 of which 312 recycled Never used RAM 100332, free system stack 200 words Tasks: NETWORK(ready,27.1%,220) ETHERNET(notifyWait,0.2%,568) HEAT(notifyWait,0.0%,328) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,798) CanSender(notifyWait,0.0%,335) CanClock(delaying,0.0%,349) TMC(notifyWait,8.1%,91) MAIN(running,63.9%,925) IDLE(ready,0.7%,30), total 100.0% Owned mutexes: === Platform === Last reset 00:00:18 ago, cause: software Last software reset at 2023-02-27 10:45, reason: User, GCodes spinning, available RAM 100332, slot 2 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043c000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 126 MCU temperature: min 27.3, current 28.5, max 28.6 Supply voltage: min 24.2, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0 Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, mspos 8, reads 35321, writes 14 timeouts 0 Driver 1: standstill, SG min 0, mspos 8, reads 35321, writes 14 timeouts 0 Driver 2: standstill, SG min 0, mspos 8, reads 35322, writes 14 timeouts 0 Driver 3: standstill, SG min 0, mspos 8, reads 35322, writes 14 timeouts 0 Driver 4: standstill, SG min 0, mspos 8, reads 35325, writes 11 timeouts 0 Driver 5: standstill, SG min 0, mspos 8, reads 35325, writes 11 timeouts 0 Date/time: 2023-02-27 10:45:43 Slowest loop: 1.69ms; fastest: 0.05ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 25.0MBytes/sec SD card longest read time 0.7ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === CAN === Messages queued 184, received 529, lost 0, boc 0 Longest wait 3ms for reply type 6026, peak Tx sync delay 622, free buffers 50 (min 49), ts 92/91/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 2.41ms; fastest: 0.03ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 1 of 8 = Ethernet = State: active Error counts: 0 0 0 1 0 0 Socket states: 2 2 2 2 2 0 0 0 === Multicast handler === Responder is inactive, messages received 0, responses 0
I'm really grateful for everyone's help and input.
Thank you.
@Dizzwold it will switch into SBC mode if it can't read the SD card. If the SD card was still in the socket at that time, it may be faulty.
@dc42 said in Changed ISP:
Which would have been faulty, the SD card or the socket?
The SD card was in the socket at the time.
@Dizzwold said in Changed ISP:
Could be either.
Are you still having issues with it, or is it working fine now?
You could replace the SD card to be on the safe side. Usually if the socket is the problem it doesn't suddenly start working again unless it's a cold solder joint that gets affected by thermal expansion.
Ah, Okay...
It's not been used for around 3 weeks and the cupboard I keep it in (my printer cupboard), is usually around 15˚c if its door is left closed and not in use (possibly lower than that overnight). It's a double wall to the outside, but a very small cavity, so I've studded this with Rockwool, soundproof plaster board and Tecsound mass loaded vinyl sound proof membrane. Yes you could say this is cold, but it's not damp.
The SD card has been left in the board untouched, not nocked or moved in anyway until last Saturday 25/2/23 when I had the issues.
I'll have to take the board of it's mounting to look and take some pictures of the SD card readers solder joints, and the reader itself.
Like I say, it all of a sudden sprang back into life and I've ran a 10 hour print today with no issues?
Dizzwold.
