Temperature offset?
Try moving the sensor to a different input. It is possible you have a bad ADC channel.
@mendenmh @achrn @Phaedrux @DIY-O-Sphere @infiniteloop
So yeah, I connected the sensor to temp2 instead of temp1, and get normal temperatures now. Does this mean my temp1 connection is shot on this board? I wouldn't be very happy about that...
Also, what is an ADC channel?Anyway, I can print again now, So I guess I'll get started on that
Thanks everyone!
@Queevix said in Temperature offset?:
Analog Digital Conversion. It's the part that takes the analog signal from the temp sensor and converts it to a digital representation.
When and where did you get the board?
Can you try updating your firmware by uploading this zip file to the system tab in DWC? Just in case.
https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zip
