    Thermistor 104nt-4-r025h42g
    2.5k
    • Mike 1undefined
      Mike 1 @T3P3Tony
      @T3P3Tony
      P"e0temp" did not help the heater ist n/a
      I think the resistance is not a big issue because this here worked:
      M305 S"T0" P1 T100000 B4138 C0
      • T3P3Tonyundefined
        T3P3Tony administrators
        @MIke-1 I checked your wiring image again, posting here to make it easier to reference:
        67f5df62-9fd9-46c0-89ac-224da8bb42c7-image.png https://forum.duet3d.com/assets/uploads/files/1677954007806-87d3ed42-0e46-4a99-b7dd-e0b7291af44d.jpg
        And it does look like you have something plugged into e0temp so something else is failing please send M98 Pconfig.g from the console and see what errors you get back.
        www.duet3d.com
        Mike 1undefined 1 Reply Last reply Reply Quote 0
        • Mike 1undefined
          Mike 1 @T3P3Tony
          @T3P3Tony said in Thermistor 104nt-4-r025h42g:
          M98 Pconfig.g
          My latest config is uploaded Here is the respondse, but it does not make sense to me:
          M98 Pconfig.g
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          Error: Unknown pin name 'duex.e1heat'
          Error: Heater 1 not found
          Error: Heater 1 does not exist
          Error: Sensor 4 does not exist
          Error: Bad command: mp"" Y"thermistor" T100000 B4138
          Error: in file macro line 108: M308: missing parameter 'S'
          Error: Heater 4 not found
          Error: Heater 4 does not exist
          Error: Unknown pin name 'duex.fan0'
          Error: Fan number 0 not found
          Error: Unknown pin name 'duex.fan1'
          Error: Fan number 1 not found
          Error: Unknown pin name 'duex.fan2'
          Error: Fan number 2 not found
          Warning: Heater 0 predicted maximum temperature at full power is 403°C
          Warning: Heater 2 predicted maximum temperature at full power is 842°C
          Warning: Heater 3 predicted maximum temperature at full power is 494°C
          Error: Heater 5 not found
          Error: Heater 6 not found
          Error: Heater 7 not found
          • T3P3Tonyundefined
            T3P3Tony administrators @Mike 1
            @MIke-1 now we are getting somewhere. We need to fix those errors.
            if you look in the documentation here:
            https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_Overview#pin-names
            you will not find "duex.e1heat" the e1heat connector is on the duet 2 mainboard so change that to "e1heat" without the duex and then restart and run M98 Pconfig.g again
            you will hopefully see that first error disappear and then probably the next two which relate to heater 1 not being setup correctly.
            Next error, these three lines:
            This line is possibly the culprit
            M308 S4 P"duex.e5temp" Y"thermistor" T100000 B4138
            try the following in its place
            M308 S1 P"e5temp" Y"thermistor" T100000 B4138
            Once again save, run M98 Pconfig.g and lets see if thats fixed some more of the issues.
            Using the same process have a a go fixing the other errors.
            www.duet3d.com
            • Mike 1undefined
              Mike 1 @T3P3Tony
              M98 Pconfig.g
              Now it looks better:
              M98 Pconfig.g
              FTP is disabled
              TELNET is disabled
              Error: in file macro line 109: M308: missing parameter 'S'
              Warning: Heater 1 predicted maximum temperature at full power is 715°C
              I updated the config but do not understand the issue.
              The thermistor is the upper one with the 2 blue and 2 yellow wires just using 2
              config(1).g
              • T3P3Tonyundefined
                @MIke-1
                See this from me previous reply:
                www.duet3d.com
                • Mike 1undefined
                  Mike 1 @T3P3Tony
                  @T3P3Tony
                  ; Heater4
                  ;M308 S1 P"e5temp" Y"thermistor" T100000 B4138
                  M308 S4 "P"duex.e3temp"" Y"thermistor" T100000 B4138 ; configure sensor 4 as thermistor on pin duex.e6temp
                  M308 H4 C"duex.e3heat" T4 ; create nozzle heater output on duex.e6heat and map it to sensor 4
                  M307 H4 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                  M143 H4 S280
                  This here is said to be the faluty line:
                  Here is the response:
                  M98 Pconfig.g
                  FTP is disabled
                  TELNET is disabled
                  Error: in file macro line 110: M308: missing parameter 'S'
                  But why S1 in M308 S1?
                  • T3P3Tonyundefined
                    @MIke-1 said in Thermistor 104nt-4-r025h42g:
                    sorry my cut and paste mistake. it should have been
                    M308 S4 P"e5temp" Y"thermistor" T100000 B4138
                    to replace this line
                    if S4 is actually connected to e3temp rather than e5temp then adjust the line accordingly.
                    www.duet3d.com
                    • Mike 1undefined
                      Mike 1
                      @T3P3Tony
                      M98 Pconfig.g
                      FTP is disabled
                      TELNET is disabled
                      Error: in file macro line 111: M308: missing parameter 'S'
                      This is the current code:
                      ; Heater4
                      ;M308 S4 "P"duex.e3temp"" Y"thermistor" T100000 B4138
                      M308 H4 C"duex.e3heat" T4 it to sensor 4
                      M143 H4 S280 ; set temperature limit for heater 4 to 280C
                      I think this should work
                      M308 S4 P"duex.e3temp" Y"thermistor" T100000 B4138 ; the yellow and blue cable on the picture on the extension board
                      M308 H4 C"duex.e3heat" T4 ; heater 3 on the extension board
                      Thanks a lot!!!
                      • T3P3Tonyundefined
                        @MIke-1 that yellow and blue cable looks like its wired to a PT100 because its 4 wires not 2. but that aside, there is a fault in the config.g that it preventing the sensor from being created. looking at it with fresh eyes i think i spot the issue, there is another M308 in there which should be a M950
                        please replace this:
                        ; Heater4
                        with this
                        ; Heater4
                        M308 S4 P"e3temp" Y"thermistor" T100000 B4138
                        M950 H4 C"duex.e3heat" T4 it to sensor 4
                        I don't necessarily think we will get a correct temperature reading but we should get a configuration that stops failing at that point.
                        Also please update this table:
                        H1 T0 is linked to with 2 cables to E0Temp 9,4kOhm
                        H2 T1 is linked to the bottom board with the resistor 108Ohm
                        H3 T2 is linked with 4 wires connected to one of the top 150kOhm
                        H4 T3 is linked with 2 cables to E5Temp 9,4kOhm
                        because it looks like at least H4 is using S4 and is using a 4 wire sensor.
                        www.duet3d.com
                        • Mike 1undefined
                          Mike 1 @T3P3Tony
                          @T3P3Tony
                          M98 Pconfig.g
                          FTP is disabled
                          TELNET is disabled
                          Warning: Heater 4 predicted maximum temperature at full power is 575°C
                          The T3 cable has 4 wire but is connected to only 2 pins on the board.
                          H1 T0 is linked to with 2 cables to E0Temp 9,4kOhm ;Sensor is on H1 and working
                          H4 T3 is linked with 2 cables to E3Temp 9,4kOhm ;Sensor is on H4 and working
                          Now it is time to fix the other 2 sensors 🙂
                          • Mike 1undefined
                            Mike 1 @Mike 1
                            @MIke-1
                            T1 is working 🙂
                            M308 S2 P"spi.cs1" Y"rtd-max31865"
                            T2 is a 104nt-4-r025h42g should it be pluged into the board itself? How do I connect to that sensor?
                            M308 S3 P"spi.cs3" Y"104GT-2" is not working
                            M98 Pconfig.g
                            FTP is disabled
                            TELNET is disabled
                            Error: Unknown sensor type name "104gt2"
                            Warning: Sensor number 3 has not been defined
                              Phaedrux Moderator @Mike 1
                              Yes if it's a normal thermistor it needs to be connected to the board itself on a temperature input and not the PT100 daughterboard.
                              Then you'd need commands similar to these depending on what pin you use and what values are needed for the thermistor.
                              M308 S4 P"e3temp" Y"thermistor" T100000 B4725 C7.06e-8
                              This is just an example though.
                              Can you post your config.g as it currently is now?
                              • Mike 1undefined
                                Mike 1 @Phaedrux
                                @Phaedrux
                                Now the heaters are all working 🙂
                                I used another plug for the sensor.
                                Sensorless homing is crashing at least for the x axis.
                                config(2).g
                                  Might be a good idea to start a new thread about this issue. Include your config.g and homing files.
                                  • T3P3Tonyundefined T3P3Tony marked this topic as a question
                                  • T3P3Tonyundefined T3P3Tony has marked this topic as solved
