    Thermistor 104nt-4-r025h42g
    2.5k
    • Mike 1undefined
      Mike 1 @T3P3Tony
      @T3P3Tony
      M98 Pconfig.g
      HTTP is enabled on port 80
      FTP is disabled
      TELNET is disabled
      Warning: Heater 0 predicted maximum temperature at full power is 403°C
      Warning: Heater 1 predicted maximum temperature at full power is 715°C
      Warning: Heater 2 predicted maximum temperature at full power is 842°C
      Warning: Heater 3 predicted maximum temperature at full power is 494°C
      Warning: Heater 4 predicted maximum temperature at full power is 575°C
      Error: Heater 5 not found
      Error: Heater 6 not found
      Error: Heater 7 not found
      The T3 cable has 4 wire but is connected to only 2 pins on the board.
      H1 T0 is linked to with 2 cables to E0Temp 9,4kOhm ;Sensor is on H1 and working
      H2 T1 is linked to the bottom board with the resistor 108Ohm
      H3 T2 is linked with 4 wires connected to one of the top 150kOhm
      H4 T3 is linked with 2 cables to E3Temp 9,4kOhm ;Sensor is on H4 and working
      Now it is time to fix the other 2 sensors 🙂
      Mike 1undefined 1 Reply Last reply Reply Quote 0
      • Mike 1undefined
        Mike 1 @Mike 1
        @MIke-1
        T1 is working 🙂
        M308 S2 P"spi.cs1" Y"rtd-max31865"
        T2 is a 104nt-4-r025h42g should it be pluged into the board itself? How do I connect to that sensor?
        M308 S3 P"spi.cs3" Y"104GT-2" is not working
        M98 Pconfig.g
        FTP is disabled
        TELNET is disabled
        Error: Unknown sensor type name "104gt2"
        Warning: Sensor number 3 has not been defined
          Phaedrux Moderator @Mike 1
          @MIke-1 said in Thermistor 104nt-4-r025h42g:
          Yes if it's a normal thermistor it needs to be connected to the board itself on a temperature input and not the PT100 daughterboard.
          Then you'd need commands similar to these depending on what pin you use and what values are needed for the thermistor.
          M308 S4 P"e3temp" Y"thermistor" T100000 B4725 C7.06e-8
          M950 H4 C"duex.e3heat" T4 it to sensor 4
          This is just an example though.
          Can you post your config.g as it currently is now?
          • Mike 1undefined
            Mike 1 @Phaedrux
            @Phaedrux
            Now the heaters are all working 🙂
            I used another plug for the sensor.
            Sensorless homing is crashing at least for the x axis.
            config(2).g
              Might be a good idea to start a new thread about this issue. Include your config.g and homing files.
              • T3P3Tonyundefined T3P3Tony marked this topic as a question
              • T3P3Tonyundefined T3P3Tony has marked this topic as solved
