Solved Help
Hi all, I swapped the FLSun SR delta printer card with a wifi duet2, but I can't configure it, could you help me? Thank you
my configuration:
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet WiFi 1.02 or later
Board ID: 08DGM-917NK-F23T0-6JTD0-3S06T-TYAJF
Used output buffers: 1 of 26 (13 max)
Static ram: 23836
Dynamic ram: 74544 of which 24 recycled
Never used RAM 13580, free system stack 134 words
Tasks: NETWORK(notifyWait,14.8%,237) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,294) MAIN(running,85.1%,408) IDLE(ready,0.1%,30), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:26:46 ago, cause: software
Last software reset at 2023-02-26 15:13, reason: User, GCodes spinning, available RAM 13604, slot 2
Error status: 0x00
Aux0 errors 0,0,0
Step timer max interval 0
MCU temperature: min 30.5, current 31.1, max 32.0
Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
Events: 0 queued, 0 completed
Driver 0: standstill, SG min 0
Driver 1: standstill, SG min 0
Driver 2: standstill, SG min 0
Driver 3: standstill, SG min n/a
Driver 4: standstill, SG min n/a
Driver 5:
Driver 6:
Driver 7:
Driver 8:
Driver 9:
Driver 10:
Driver 11:
Date/time: 2023-02-26 15:40:38
Slowest loop: 10.29ms; fastest: 0.15ms
=== Storage ===
Free file entries: 10
SD card longest read time 4.5ms, write time 0.0ms, max retries 0
DMs created 83, segments created 4, maxWait 26075ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 12, completed 12, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
=== AuxDDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty
=== Network ===
Slowest loop: 15.86ms; fastest: 0.00ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
HTTP sessions: 1 of 8
= WiFi =
Network state is active
WiFi firmware version 1.26
WiFi MAC address 84:0d:8e:b3:b4:8a
WiFi Vcc 3.39, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 26208
WiFi IP address 192.168.1.9
WiFi signal strength -69dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
Socket states: 0 0 0 0 0 0 0 0 -
@Leblond
Problem 1:
I can't home the printer correctly without getting an error like (G28
Error: G0/G1: target position not reachable from current position)Problem 2:
I can't use the original printer probe, the connections are correct and the program sees it as such, but the printer doesn't stop even if I manually activate it -
; Endstops M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
Your endstop configuration is incorrect for a delta. You must use X2 Y2 Z2 because the endstops are at the high end of the axis.
@Phaedrux
ok I'll try tomorrow -
@Phaedrux X2 Y2 Z2 works, but I have a serious problem that I can't solve, pressing the switch manually on the screen it shows me that it works but once I start probing the work surface the nozzle crashes on the surface
@Phaedrux I took +5v on the expansion connector, GND+Zprobe on the ZPROBE connector
What kind of probe is it?
Have you tested the probe in isolation yet? https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing#dynamic-test
What gcode are you running to start the probing?
Share your bed.g
@Phaedrux
Inglese
si l'ho provato e funziona, da 0 a riposo a mille quando lo premo, e ho provato anche al rovescio da 1000 a 0 sempre manualmente e funziona, nel momento in cui vado a sondare il letto se non metto la mano sotto il probe non si ferma e si schianta sul letto, non ne riesco ad uscire, ho provato anche a cambiare l'input di ingresso ed e uguale al precendente, domaninmattina ti posto il bed.g
yes I tried it and it works, from 0 at rest to a thousand when I press it, and I also tried it backwards from 1000 to 0 always manually and it works, when I go to probe the bed if I don't put my hand under the probe it does not stop and crashes on the bed, I can't get out of it, I also tried to change the input input and it is the same as the previous one, tomorrow morning I'll post the bed.g -
What type of probe is it?
Does the probe status show 0 or 1000 in the DWC window?
You may need to invert the probe signal.
I would suggest you try this
M558 P8 C"!zprobe.in" H10 F120 T6000
Then send G28 to home the towers and then G30 to test the probe. Trigger it by hand just in case and be ready to cut the power if it doesn't respond.
@Phaedrux
hi so the settings i used are:M558 P8 C"!zprobe.in" H10 F120 T6000 reset to initial dwc 0, if I put my hand underneath and press it it goes to 1000.
M558 P8 C"^zprobe.in" H10 F120 T6000 result in initial dwc 1000, if I put my hand below it goes to 0
I made a G30 and it works but I don't understand why when I go to make a G32 it doesn't work
@Phaedrux
Funziona tutto -
@Phaedrux
Thanks guy, the problem was that I didn't know that when you do a G32 that then it goes to call the BED.G
the probe does not activate in the moment of fast descent towards the floor, but it activates in the moment in which it proceeds with the probing coordinates, I thought that the probe activated in the moment in which the G32 command is given, while if the command is given G30 followed by the coordinates the probe is active -
