Sensorless homing with dual Y motors.
I have a custom build I am working on that is utilizing dual Y motors on a duet 3 and expansion board and toolboard. I have all of the firmware up to date on each of the boards. I am trying to get my sensorless homing resolved and found out that every other time I home with Y it only uses one Y motor and swaps to the other Y motor every other time. I have uploaded my config.g and my homey.g I also have video showing it doing this. Any ideas?
Can you post your video?
Firmware version?
Have you done any of the sensitivity tuning required for stall detection?
https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_stall_detection
@Phaedrux I have done all of this. Literally one motor spins on the first home sequence and then the other motor spins on the second sequence. So I am only getting one motor at a time on homing. Also to note I have modified my config.g a little and it seems to have made things a little more consistant. config (3).g working on uploading the video to drive now since I can't directly here because of the size.
M913 Y95 ; reduce motor current to 45% to prevent belts slipping
You're not actually dropping the current all that much. The comment says 45%, but the actual command is 95.
You may also want to look into M201.1 to reduce acceleration for homing.
Your config also has M584 defined twice.
Firmware version?
@Phaedrux said in Sensorless homing with dual Y motors.:
M201.1
3.4.5 and M201.1 is that new? because 201 doesn't work like it used to. I used to use M201 and M205 so now your saying I need to call M201.1 I also got both axis working by specifying my second Y as A for it's axis and then hiding it and reclassifying it in my home file at the end.
@wdenker said in Sensorless homing with dual Y motors.:
What do you mean by this?
M201.1 is new and optional. It's the same as setting M201 manually in certain cases.
Splitting the axis is another way to go.
@Phaedrux Ya I created a new A axis and I used to could use M201 but I guess they implemented 201.1 now for homing. I was able to get this resolved by creating the new A axis and using M201.1 to slow it down on homing. Thanks!
@wdenker it should be possible to home dual Y axis motors without splitting the motors into separate axes, but you may need to use M201.1 to reduce the acceleration in order to prevent one of the motors stalling immediately.
@dc42 I was only able to get them to work together on a home by creating a second axis and hiding that axis and homing them together.
