    Driver 1
    • abindarraez1undefined
      abindarraez1
      Hi my drive 01 has failed.
      It indicates a short to ground by my drive 1.
      It is very strange because I made sure there was no loose screw and was very careful.
      But It has a short to ground.
      I bought the board less than two months ago from Filastruder.
      Could I get a replacement?
        What Duet board is it?
        Which motor do you have assigned to driver 1?
        If you connect a different motor to that driver or no motor at all, does the error persist?
        Do you see any visible damage to the driver 1 chip? Can you post photos?
        abindarraez1undefined 1 Reply Last reply Reply Quote 0
          abindarraez1 @Phaedrux
          The Board is a brand-new Duet 5 Mini Ethernet.
          Both Drives 2 and 3 were working well.
          But I changed the Motor and the error persists.
          I will post a picture but I see no external damage.
            abindarraez1 @abindarraez1
            @abindarraez1 alt text
              Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
              In the meantime you can rebind the axis to a spare driver to get up and running.
                @Phaedrux Thanks
                • T3P3Tonyundefined T3P3Tony marked this topic as a question
                • T3P3Tonyundefined T3P3Tony has marked this topic as solved
