Bug: layer time graph starts at 2.
Duet Web Control
478
  • undefined
    zBeeble
    So... seems like I only pop in here when I'm having a problem. Sorry about that.
    Anyways, possibly not all the time, my web control displays layer timing from layer 2 onwards. I have multiple web browsers watching the printer --- one near the printer and one in my home office. The included pic is from my home office that did not start the print.
    undefined 1 Reply Last reply 5 Mar 2023, 20:58 Reply Quote 0
    • undefined
      T3P3Tony administrators @zBeeble
      @zBeeble which version of RRF/DWC are you using?
      www.duet3d.com
      undefined 1 Reply Last reply 8 Mar 2023, 19:35 Reply Quote 0
      • undefined
        zBeeble @T3P3Tony
        @T3P3Tony
        I think that's what you're asking?
        • undefined
          Can you try updating to the latest?
          Upload this zip file to the system tab in DWC.
          https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.5/Duet2and3Firmware-3.4.5.zip
          undefined 2 Replies Last reply 9 Mar 2023, 17:46 Reply Quote 0
          • undefined
            zBeeble @Phaedrux
            @Phaedrux urg. Where's the changelog again? I'm so change adverse ... urg.
            undefined 1 Reply Last reply 9 Mar 2023, 19:55 Reply Quote 0
            • undefined
              Phaedrux Moderator @zBeeble
              @zBeeble https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x#reprapfirmware-345
              undefined 1 Reply Last reply 10 Mar 2023, 22:24 Reply Quote 0
              • undefined
                zBeeble @Phaedrux
                @Phaedrux Thx. Seems the most major changes have been 3.4.1 to .2 ... sigh. I dislike change.
                • undefined
                  zBeeble @Phaedrux
                  @Phaedrux OK. Did the upgrade. No change. I took a pick at layer 2 (so showing layer one on the graph) and then at 3, 4, 5 and 6. You can imagine the rest. If it gets to 30, clicking on the "show all" link shows it from 1, but otherwise it's from 2.
                  • undefined
                    Can you share the gcode file and your config.g?
                    • undefined
                      zBeeble
                      @Phaedrux sure. Note that this happens with multiple different files, but the particular one printing above is the 2nd include.
                      ... hrm... at least one of my files is too big. Here's nextcloud links:
                      The config.g:
                      https://nextcloud.towernet.ca/s/nRAsmqJQYECKxQS
                      This is the file that was printing in the above pictures.
                      https://nextcloud.towernet.ca/s/fFbo9KDoRpy7fFN
                      undefined 1 Reply Last reply 21 Mar 2023, 10:49 Reply Quote 0
                      • undefined
                        @chrishamm can you have a look here, any reason for the first layer to be not shown after layer 2?
                        www.duet3d.com
                        undefined 1 Reply Last reply 13 Apr 2023, 12:12 Reply Quote 0
                        • undefined
                          chrishamm administrators @T3P3Tony
                          @T3P3Tony @zBeeble The first layer is usually pretty slow compared to others (especially when printing lots of items at once), so DWC hides the first layer once the second one is complete. So it isn't really a bug, it's a feature.
                          I'll check if I can bring back panning and zooming in DWC 3.6, which would eliminate the current limitation. Unfortunately panning and zooming was broken in several ChartJS versions, so I haven't tried to restore this behaviour for a while.
                          Duet software engineer
                          undefined 1 Reply Last reply 13 Apr 2023, 12:22 Reply Quote 0
                          • undefined
                            T3P3Tony administrators @chrishamm
                            @chrishamm in the meantime, how about a checkbox "hide layer 1" which the user can tick or not.
                            www.duet3d.com
                            undefined 1 Reply Last reply 13 Apr 2023, 12:28 Reply Quote 0
                            • undefined
                              dc42 administrators @T3P3Tony
                              @T3P3Tony said in Bug: layer time graph starts at 2.:
                              I'm not in favour of adding complexity to the UI for doubtful utility.
                              undefined 1 Reply Last reply 13 Apr 2023, 15:41 Reply Quote 1
                              • undefined
                                T3P3Tony administrators @dc42
                                @dc42 we can always add it in the setting->general along with other UI settings that are already there. Right now, as its hidden, it causes confusion as the feature of hiding it is unknown.
                                www.duet3d.com
