Configuration of OUT_7 connector on Duet3-6HC
Hi, I'm having problems with configuration of OUT_7 connector. COuld anybody help me with that?
This is what I've tried:
M950 F0 C"out7"
to configure the connectorM106 F0 S...
- to enable/disable it. However, what I observe is that there is always 24V (VIN) on this connector, while I am expecting to see variable output between 0 and 24, as from a normal PWM-capable output.
What is wrong in my configuration? Thanks
@Arplyu how are you measuring the 24v? there is always power on the positive side of the connector. all the switching takes place on the negative side
@jay_s_uk I've connected oscilloscope to OUT_7, and what I see is continuous straight line at 24V
@jay_s_uk my bad, I'm lacking knowledge in electronics
The easiest way was just to test with a real fan, which I have done now. Everything works as expected.
undefined T3P3Tony marked this topic as a question
undefined T3P3Tony has marked this topic as solved
