Controlling Duet 3 from Linux (Non-SBC)
369
  • undefined
    shyam98
    Hello!
    I am fairly new to Duet3D and RRF. I have an application where I would like to control multiple "3D Printers" via a single PC / Linux server. I know that with Klipper, you can directly control hardware over USB from a central computer (sbc or otherwise).
    I already have a Duet3 Mainboard 6HC and was wondering if it was possible with this board.
    Is it possible to send hardware commands over ethernet or usb to the Duet3 Mainboard?
    Would I be better off getting a Klipper setup?
    Thanks!
    undefined 1 Reply Last reply 13 Mar 2023, 14:41 Reply Quote 0
    • undefined
      achrn
      https://github.com/Duet3D/RepRapFirmware/wiki/HTTP-requests
      https://forum.duet3d.com/topic/31648/how-to-communicate-between-a-duet-and-python/3 and subsequent in the thread
      undefined 1 Reply Last reply 12 Mar 2023, 11:06 Reply Quote 1
      • undefined
        shyam98 @achrn
        @achrn Interesting, thank you!
        Do you happen to know the type of speeds you could achieve for continuous calls from the on-board HTTP interface? Would sending too many requests slow down the rest of the system?
        undefined 1 Reply Last reply 12 Mar 2023, 11:10 Reply Quote 0
        • undefined
          achrn @shyam98
          @shyam98 sorry, I've never used it to stream a lot of commands in sequnece - I have a routine that uses the interface, but I assemble a gcode file, upload it and run it, so it's only a few commands directly over the http interface.
          undefined 1 Reply Last reply 12 Mar 2023, 11:17 Reply Quote 1
          • undefined
            shyam98 @achrn
            @achrn Gotcha!
            I am hoping to get some data back from the system in semi-real-time (0.2 seconds or so) so I will do some experimenting and see if how it affects the motion.
            undefined 1 Reply Last reply 12 Mar 2023, 11:46 Reply Quote 0
            • undefined
              jay_s_uk @shyam98
              @shyam98 a print farm software solution is going to be released as part of 3.5
              • undefined
                dc42 administrators @shyam98
                @shyam98 said in Controlling Duet 3 from Linux (Non-SBC):
                Yes you can stream commands over USB, but you will lose some of the advantages of printing from SD card, such as fast pause i.e. being able to pause the print without having to execute all the movement commands that are already buffered first.
                undefined 1 Reply Last reply 15 Mar 2023, 14:13 Reply Quote 0
                • undefined
                  shyam98 @dc42
                  @dc42 Have you heard of anyone experimenting on the speed at which the stream will work? Just wondering how many lines need to be buffered at a time. In this scenario, the "printer" is acting as part of a dynamic system and its code / function might need to change depending on sensor going to a higher level controller in the system.
                  6 out of 8
