    filament position to Arduino over Panel due interface
    PanelDue
    panel due filament sensor
    • CNCModellerundefined
      CNCModeller
      Hi All,
      After participating in this thread;
      https://forum.duet3d.com/topic/31702/filament-diameter-compensation/9
      I think its potentially viable to use an Arduino based filament sensor that receives extruded filament length and pushes appropriate filament diameter corrections over the panel due interface.
      I think I can push corrections by using the Arduino code for the CNC pendant as a starting point but I don't know how to read the current filament extrusion length from the panel due interface.
      Is the panel due message set defined anywhere? If so is it something I can read with an Arduino? I assume so given the pendant does pass through.
      Also could I use a dedicated gcode command to send a message over the panel due interface to the Arduino to set the distance between the sensor and nozzle?
      Any constructive thoughts would be much appreciated.
      All the best
      Barry M
      Polar Duet3 Mini + 1HCL
      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
      Wanhao D4S: Duet2
      https://forum.duet3d.com/post/296755
      K40 Laser, Duet2
      https://forum.duet3d.com/post/312082
      Wanhao D5S
      https://www.youtube.com/CNCModellerUK
      • T3P3Tonyundefined
        T3P3Tony administrators @CNCModeller
        @CNCModeller the PanelDue uses the object model information so you can query that over the UART interface using M409
        www.duet3d.com
        CNCModellerundefined 1 Reply Last reply Reply Quote 0
          CNCModeller @T3P3Tony
          @T3P3Tony said in filament position to Arduino over Panel due interface:
          That's great news, I now need to figure out what that actually means lol. Definitely some reading ahead!
          Many thanks @T3P3Tony, time to go back to school... again... 馃槈
          Cheers
          Barry M
          Wanhao D4S: Duet2
          K40 Laser, Duet2
          Wanhao D5S
            CNCModeller
            So after some research.... and a quick look at the PrintEye code by @EasyTarget
            https://forum.duet3d.com/post/110578
            I think I have a plan based on the Json unpacking in PrintEye, to extract the following data:
            extr: the positions of the extruders
            efactor: the current extrusion factors (see M221 command), one value per extruder
            Then sending a M221 to tune the extrusion factor after a user defined position delay based on filament path length between the sensor and the extruder melt zone.
            The only kink is I'm not sure how to send a value to the Arduino to set the filament path length between the sensor and the extruder melt zone. I may have to hard code this to start with, or add a local display to set the value.
            Does anyone know if I can add user defined elements to the json package sent to the Arduino as a response to M408? My thoughts are set a value for the filament path delta for each extruder with a user defined G/MCode (?) in the config.g.
            I need to do some prototyping and merge it with Thomas Sanladerer's code and I possibly have a way forward!
            https://www.printables.com/model/57154-infiDANK
            https://www.youtube.com/watch?v=RYgdLPe_T0c
            Multiple extruders needs a little thinking but I guess I could just connect multiple sensors to the one Arduino.
            Also passthrough for the PanelDue, but I could use the code by @dc42 for the CNC pendant to sort that.
            Will report back as and when I make progress! Another project to add to the list 馃檪
            Cheers
            Barry M
            Wanhao D4S: Duet2
            K40 Laser, Duet2
            Wanhao D5S
