    Z-probe offset
    Firmware installation
    • Reineundefined
      Reine
      Quick question regarding Z-probe offset, given the position in the image.
      It sits infront, to the left of the nozzle -- would that positive or negative XY numbers?
      Norderundefined 1 Reply Last reply Reply Quote 0
      • Norderundefined
        Norder @Reine
        @Reine
        That would be negative values.
        DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
        Thingiverse
        Reineundefined 1 Reply Last reply Reply Quote 1
        • Reineundefined
          Reine @Norder
          @Norder thank you for the help, greatly appreciated.
            See here for reference: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
            It's assumed that your printer will be using a right handed coordinate system because that's what CAD and slicing software uses.
            +X to the right, - X to the left, +Y to the back, -Y to the front.
