    Array Max Length
    Gcode meta commands
    • timothyzundefined
      timothyz
      I am trying to implement additional tool management capabilities for a CNC router and I am curious how long the new arrays can be? I am trying and I can't seem to declare an array that is longer than 10 or so values. Is this a limitation of the gcode parser max line length? Is there any way to multi-line this?
      Thanks,
      Tim
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @timothyz
        @timothyz
        How are you trying to do it?
        I don't know the limit or how you're trying to use the array, but as an example
        global bigArray = vector(30,0)
        echo global.bigArray
        while iterations < #global.bigArray
        	set global.bigArray[iterations]=random(100)
        G4 S1
        echo max(global.bigArray)
        timothyzundefined 1 Reply Last reply Reply Quote 0
        • timothyzundefined
          timothyz @OwenD
          @OwenD I didn't know you could declare an array that way! It won't work if I do it as one line, but this is perfect. I must have missed this in the documentation.
          Thanks again.
          I will make a new post once I have created something useful.
          • OwenDundefined
            OwenD @timothyz
            @timothyz
            Ensure you have the latest binaries
            vector() is a recent addition
            • T3P3Tonyundefined T3P3Tony marked this topic as a question
            • T3P3Tonyundefined T3P3Tony has marked this topic as solved
