    Disable Wifi of Duet2 Wifi
    • R006undefined
      R006
      Hey,
      I am trying to disable wifi of Duet2 Wifi by following below on YAT terminal.
      M552
      M552 S-1
      M552
      M552 S0
      But it's not stop and whenever power up it display Error: Wifi module reported: network scan failed.
      Any Suggestions.
        What do you have in your config.g?
        If you want to disable it every power cycle you need to have it disabled in config.g
        R006undefined 1 Reply Last reply Reply Quote 1
        • R006undefined
          R006 @Phaedrux
          @Phaedrux Ok I am try that one.
            dc42 administrators @R006
            @R006 simply remove the M552 command from your config.g file and the wifi module will remain disabled after power up.
