    Wifi Module error
    75
    • SonnyD1
      SonnyD1 last edited by SonnyD1
      304D4677-9BBA-4871-BEFA-13C9B72DEB1C.jpeg 9E821EAB-FB26-4E6B-A8B3-5996806A46C7.jpeg
      About 50% of the time when I turn my new printer on, my wifi module goes all weirdo on me. Ive updated the module itself, the paneldue, the DWC and the printer firmware (RRF3.4.5) I can send a M552S0 the a M552S1 and it will change modes and connect properly. I'd like it to work as intended if at all possible. This is a Duet 2 Wifi with a 7" paneldue.
        Can you send M122 and copy paste the results here?
        SonnyD1 1 Reply Last reply Reply Quote 0
        • SonnyD1
          SonnyD1 @Phaedrux last edited by
          @Phaedrux
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet WiFi 1.02 or later + DueX5v0.11
          Board ID: 0JD0M-9P6B2-NJ4S4-6JKFJ-3SJ6Q-T82AK
          Used output buffers: 1 of 26 (22 max)
          Static ram: 23836
          Dynamic ram: 78456 of which 12 recycled
          Never used RAM 9776, free system stack 172 words
          Tasks: NETWORK(notifyWait,29.9%,242) ACCEL(notifyWait,0.0%,348) HEAT(notifyWait,0.1%,333) Move(notifyWait,0.0%,363) DUEX(notifyWait,0.0%,24) MAIN(running,69.9%,438) IDLE(ready,0.1%,30), total 100.0%
          Owned mutexes: WiFi(NETWORK)
          Last reset 02:14:09 ago, cause: software
          Last software reset at 2023-03-17 15:01, reason: HeatTaskStuck, GCodes spinning, available RAM 9704, slot 2
          Software reset code 0x4143 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x200129c4 Task ACCE Freestk 334 ok
          Stack: 0045d7a1 0045d046 6100f000 00000000 0045d7a1 00000000 00000019 20012363 2000d31c 20012430 2000d31c 00000019 00000000 00000028 0045d8bf 20012340 20012340 00000006 0045af57 7c000000 00434fd7 7c000000 20012340 20012340 00456b8b 7c000000 20012340
          Error status: 0x08
          Aux0 errors 0,0,0
          Step timer max interval 0
          MCU temperature: min 29.5, current 29.9, max 31.4
          Supply voltage: min 23.8, current 24.1, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
          Events: 0 queued, 0 completed
          Driver 0: standstill, SG min n/a
          Driver 1: standstill, SG min n/a
          Driver 2: standstill, SG min n/a
          Driver 3: standstill, SG min n/a
          Driver 4: standstill, SG min n/a
          Driver 5: standstill, SG min n/a
          Driver 6: standstill, SG min n/a
          Driver 7: standstill, SG min n/a
          Driver 8: standstill, SG min n/a
          Driver 9: standstill, SG min n/a
          Driver 10:
          Driver 11:
          Date/time: 2023-03-17 17:15:38
          Slowest loop: 11.49ms; fastest: 0.19ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 3.8ms, write time 0.0ms, max retries 0
          DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          === AuxDDARing ===
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty
          === Filament sensors ===
          Extruder 0 sensor: no filament
          Extruder 1 sensor: no filament
          === DueX ===
          Read count 1, 0.01 reads/min
          === Network ===
          Slowest loop: 30.60ms; fastest: 0.00ms
          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
          HTTP sessions: 1 of 8
          = WiFi =
          Network state is active
          WiFi firmware version 1.27
          WiFi MAC address f4:cf:a2:68:3b:2f
          WiFi Vcc 3.39, reset reason Power up
          WiFi flash size 2097152, free heap 20616
          WiFi IP address 192.168.1.243
          WiFi signal strength -43dBm, mode 802.11n, reconnections 0, sleep mode modem
          Clock register 00002002
            Can you share your config.g please?
            • SonnyD1
              @Phaedrux
              ; Configuration file for Duet WiFi (firmware version 3.4.5)
              ; generated by RepRapFirmware Configuration Tool v3.3.15 on Sun Feb 19 2023 17:01:06 GMT-0500 (Eastern Standard Time)
              G21 ; work in milimeters
              M550 P"IDEX" ; set printer name
              M111 S0 ; debug off
              M552 S1 ; enable network
              M586 P0 S1 ; enable HTTP
              M586 P1 S1 ; enable FTP
              M586 P2 S0 ; disable Telnet
              M575 P1 B57600 S1 ; enable support for PanelDue
              M569 P0 S1 ; physical drive 0 goes forwards - X stepper
              M569 P1 S1 ; physical drive 1 goes forwards - Z stepper (left)
              M569 P2 S1 ; physical drive 2 goes forwards - Z stepper (right)
              M569 P3 S1 ; physical drive 3 goes forwards - E0 stepper
              M569 P6 S1 ; physical drive 6 goes forwards - Y stepper (left)
              M569 P7 S0 ; physical drive 7 goes backwards - Y stepper (right)
              M569 P8 S1 ; physical drive 8 gows forwards - U stepper
              M569 P9 S1 ; physical drive 9 goes forwards - E1 stepper
              M584 X0 Y6:7 Z1:2 U8 E3:9 ; set drive mapping
              M350 X16 Y16 Z16 U16 E16:16 I1 ; configure microstepping with interpolation
              M92 X80.00 Y80.00 Z800.00 U80.00 E408.21:408.21 ; set steps per mm
              M566 X600.00 Y600.00 Z60.00 U600.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min) - jerk
              M203 X6000.00 Y6000.00 Z180.00 U6000.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
              M201 X800.00 Y800.00 Z20.00 U800.00 E250.00:250.00 ; set accelerations (mm/s^2)
              M906 X1750 Y1750 Z1750 U1750 E600:600 I30 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X-26 Y0 U0 Z0 S1 ; set axis minima
              M208 X290 Y305 U320 Z300 S0 ; set axis maxima
              M574 X1 S1 P"e1stop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin e1stop
              M574 U2 S1 P"duex.e6stop" ; configure switch-type (e.g. microswitch) endstop for high end on U via pin exp.e6stop
              M574 Y1 S1 P"duex.e5stop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin exp.e5stop
              M574 Z1 S2 ; configure Z-probe endstop for low end on Z
              M591 D0 P1 C"xstop" S0 ; configure filament monitor (simple switch) for E0
              M591 D1 P1 C"duex.e4stop" S0 ; configure filament monitor (simple switch) for E1
              ; Emergency Stop
              M950 J1 C"e0stop" ; identify pin number for emergency stop
              M581 P1 T0 S1 R0 ; invoke trigger 0 when an inactive-to-active edge is detected on input 0 or input 3 and a file is being printed from SD card
              ; BLTouch
              M950 S0 C"duex.pwm1" ; create servo pin 0 for BLTouch
              M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch, connected to zprobe.in and the dive height + speeds
              G31 P500 X-31 Y-14.5 Z3.34 ; set Z probe trigger value, offset and trigger height. If you have to move the nozzle closer to the bed, increase the G31 Z value by the amount of baby stepping used. If you have to move the nozzle farther away from the bed, decrease the G31 Z value by the amount of baby stepping used.
              M557 X35:259 Y25:290 P5:5 ; define mesh grid
              M376 H10 ; taper off bed compensation over 10mm
              M308 S0 P"duex.e4temp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin duex.e4temp
              M307 H0 R0.901 K0.249:0.000 D1.86 E1.35 S1.00 B0 ; enable bang-bang mode for the bed heater and set PWM limit
              M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
              M307 H1 R4.899 K0.886:0.346 D1.80 E1.35 S1.00 B0 V24.0 ; disable bang-bang mode for heater and set PWM limit
              M143 H1 S300 ; set temperature limit for heater 1 to 300C
              M308 S2 P"duex.e3temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin duex.e3temp
              M950 H2 C"duex.e6heat" T2 ; create nozzle heater output on duex.e6heat and map it to sensor 2
              M307 H2 R4.493 K0.675:0.344 D2.01 E1.35 S1.00 B0 V24.1 ; disable bang-bang mode for heater and set PWM limit
              M143 H2 S300 ; set temperature limit for heater 2 to 300C
              M950 F0 C"fan2" Q500 ; create fan 0 on pin fan0 and set its frequency
              M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on at 45c
              M950 F2 C"duex.fan3" Q500 ; create fan 2 on pin duex.fan3 and set its frequency
              M106 P2 S0 H-1 ; set fan 2 value. Thermostatic control is turned off
              M950 F3 C"duex.fan4" Q500 ; create fan 3 on pin duex.fan4 and set its frequency
              M106 P3 S1 H2 T45 ; set fan 3 value. Thermostatic control is turned on at 45c
              M563 P0 D0 H1 F0 ; define tool 0 that used low end X carriage
              M563 P1 D1 H2 F2 ; define tool 1 that used high end U carriage
              G10 P1 X320 Y0 Z0 ; set tool 1 axis offsets
              G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
              ; Configure Accelerometer
              M955 P0 I56 C"spi.cs4+spi.cs3"
              ; IDEX
              ; Create a tool that prints 2 copies of the object using both carriages
              ;M563 P1 D0:1 H1:2 X0:3 F0:2 ; tool 2 uses both extruders, hot end heaters and fans, and maps X to both X and U
              ;G10 P1 X50 Y0 U-50 S0 R0 ; set tool offsets and temperatures
              ;M567 P1 E1:1 ; set mix ratio 100% on both extruders
              T0 ; select first tool
                Try this, remove the M552 S1 command from config.g and instead put it in a macro file in the sys folder called startwifi.g or something. Add a G4 S10 delay before the M552 S1. Then in config.g at the very end, add M98 P"startwifi.g"
                • SonnyD1
                  @Phaedrux said in Wifi Module error:
                  G4 S10
                  So after doing that and running several tests...it appears that worked. Its weird I don't have to do that on my Railcore. It starts up just fine. The paneldue reads "starting up" and after about 10 seconds it starts and a couple seconds later it connects. It looks as though that solved my problem. Thank you. Would you be willing to explain that to me so I have a better understanding?
                    Just a hunch. It seemed like it was trying to enable the module too early or something like that. Usually the M552 commands are held back until after config.g finishes executing.
                    @DC42 may have a better explanation.
