    Connecting Duet2Wifi to Rasp Pi
    • Adamfilipundefined
      Adamfilip
      I am connecting a Duet2Wifi to a Rasp Pi 4 via usb,
      so far unable to see the duet on the Pi. is there somethihng special I need to do to the Duet so they will communicate?
      Testing out klipper, I have flashed the Duet with Klipper firmware already
      markzundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
      • markzundefined
        markz @Adamfilip
        This post is deleted!
        • T3P3Tonyundefined
          T3P3Tony administrators @Adamfilip
          @Adamfilip if you clear out the firmware you should see the Duet come up as a bossa port. alternatively you could try putting RRF back on just to confirm that you can see it over USB (using a terminal program.
          www.duet3d.com
