X axis Tool head Offsets
I use duet wifi version 1.02
Firmware 3.4.5
In my machine x stop is at maximum, my first head is about 50mm when its on endstop position, 1st & 2 Tool distance is 35mm , how should i make tool offset distance?
My printable area for single head is x105,y110,z100 each, Dual print area x70,y110,z100.
and in slicer what should be the bed dimension,
Homex.g
G91 ; relative positioning
G1 H1 Y-110 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y5 F6000 ; go back a few mm
G1 H1 Y-115 F360 ; move slowly to Y axis endstop once more (second pass)
G1 H1 X105 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 X-5 F6000 ; go back a few mm
G1 H1 X105 F360 ; move slowly to X axis endstop once more (second pass)
G1 X-105 F1800
G92 X0
G90 ; absolute positioningConfig.g
M208 X105 Y110 Z135 S0 ; set axis maxima; Endstops
M574 X2 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop; Tools
M563 P0 S"Head 1" D0 H0 F0 ; define tool 0
M563 P1 S"Head 2" D1 H0 F0 ; define tool 1
G10 P1 X35 Y0 Z0 ; set tool 1 axis offsets
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C -
@adhanabal said in X axis Tool head Offsets:
Firmware 3.4.5
Homex.g
G1 X-105 F1800
G92 X0
undefined Phaedrux moved this topic from Firmware installation
I'm not totally clear what question you have.
G1 X-105 F1800
G92 X0This is confusing to me. If the maxima in M208 is correct, you shouldn't need the move to the minimum and setting X0 there. What effect is that having for you?
The slicer bed dimension should be your full bed area. The slicer will also likely have the option to define the offset of the second tool.
Is the physical travel limited to just the bed area, or can it go off the edge?
@Phaedrux hi thank you, i have actually fixed the issue
@adhanabal That's great. How did you resolve it?
@Phaedrux I adjusted bed size in slicer and mentioned tool offset
and created custom bed image to avoid placing the object in wrong position in the bed for tool heads. -
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
