Steel bed
Anyone know what type of steel they make spring steel sheets from? 1095?
Probably. Anything from 1050 on up if you can get it heat treated. 301 stainless would be a great choice because of its corrosion resistance but it's higher CTE may not be so great. It may not like the temperature and warp. Either way you probably cant go wrong with 1095
