    2 of my Triple Z motors moving twice as far
    300
    • cdsmith12undefined
      cdsmith12
      So, I originally started with a Vulcanus 40, but changed it several times. Now I have kind of a combination of BLV and a Ratrig CoreXY. I was having some problems with my bed and decided to eliminate the 4 pieces of 2020 and 4mm aluminum plate (about 5 lbs.) from the original Vulcanus design and change from 2 leadscrews with 4 linear rails to a Triple motor kinematic style. I also added a Duex5
      I used my old config file and edited it for 3 Z motors. Now my rear single motor is moving correctly, but the right and left front motors are moving exactly twice the distance. Their are probably other issues in my file, but I want to get the Z axis working first.
      Any assistance is appreciated.
      Config.g
      ; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jun 14 2020 23:31:14 GMT-0500 (Central Daylight Time)
      M550 P"The Plastic Beast" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes forwards
      M569 P1 S0 ; physical drive 1 goes forwards
      M569 P2 S0 ; Z front left physical drive 2 goes backwards
      M569 P5 S0 ; Z front right physical drive 5 goes backwards
      M569 P6 S0 ; Z middle rear physical drive 6 goes backwards
      M584 X0 Y1 Z2:5:6 ; three Z motors connected to driver outputs 2, 5 and 6
      M671 X-60:460:205 Y5:5:445 S0.5 ; leadscrews at front left, rear middle and front right
      M350 Z16 E16 I0 ; configure microstepping without interpolation
      M350 X16 Y16 I1 ; configure microstepping with interpolation
      M92 X79.40 Y79.40 Z800.00 E399.40 ; set steps per mm
      M566 X1000.00 Y1000.00 Z100.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X24000.00 Y24000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
      M906 X1400 Y1400 Z1400 E950 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X399 Y410 Z400 S0 ; set axis maxima
      M574 Z1 S2 ; configure Z-probe endstop for low end on Z
      M950 S0 C"duex.pwm1" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F100 T4000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-26 Y1.7 Z1.135 ; set Z probe trigger value, offset and trigger height
      M557 X5:372 Y7:405 S20 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S285 ; set temperature limit for heater 1 to 285C
      M106 P0 S0 H1 T45 ; set fan 0 value. Thermostatic control is turned on
      M912 P0 S1 ; set cpu temp offset
      M501
      T0 : select first tool
      bed.g
      ; bed.g
      G28 ; home
      G30 P0 X370 Y5 Z-99999 ; probe near left front leadscrew
      G30 P1 X30 Y5 Z-99999 ; probe near right front leadscrew
      G30 P2 X205 Y380 Z-99999 S3 ; probe near a rear middle leadscrew and calibrate 3 motors
      moth4017undefined 1 Reply Last reply Reply Quote 0
      • moth4017undefined
        moth4017 @cdsmith12
        @cdsmith12 are the stepper motors the same e.g 1.8 or 0.9 deg per step?
        cdsmith12undefined 1 Reply Last reply Reply Quote 0
          cdsmith12 @moth4017
          @moth4017
          yes all three stepper motors are the same
          • moth4017undefined
            moth4017 @cdsmith12
            @cdsmith12 Are you 3 lead screws the same Pitch? turn each one manually 1 full turn and see if each corner moves the same amount.
            cdsmith12undefined 2 Replies Last reply Reply Quote 0
              The config is correct and each motor driver will be getting the same steps. So the difference must come from a physical characteristic. Either the motors or the lead screws are not identical.
                cdsmith12 @moth4017
                @moth4017
                That was it. I bought 2, then bought 2 more a couple years later. I thought they were the same since there wasn't any issues with the lead screw nuts. I'll order a new one with the right pitch
                Thanks
                  cdsmith12 @moth4017
                  @moth4017
                  I take that back, about the coupler being the same. I had this thing all the way apart and all the pieces laying everywhere. I don't know how the heck I picked up the right coupler and leadscrew all those times and never had a mismatch until i just tried it.
                  • deckingmanundefined
                    deckingman @cdsmith12
                    @cdsmith12 Be careful when talking about pitch with regard to lead screws. The important thing is "lead" which is how far a nut will travel in one revolution of the screw. With single start threads, the lead and the pitch happen to be the same. But many lead screws have multi start threads and the lead is the pitch multiplied by the number of thread starts. So for example 2mm pitch single start thread will have a lead of 2mm, but a 2mm pitch, 2 start thread will have a lead of 4mm and a 2mm pitch 4 start thread will have a lead of 8mm. If they were laid side by side, they would look very similar because the pitch is the same. So you have to look closely at the helix angle, or at the end of the screw to notice the difference. Oh and for the Z axis of a 3d printer, 2mm lead is the optimal for reasons which I will gladly explain if necessary.
                    cdsmith12undefined 1 Reply Last reply Reply Quote 1
                      cdsmith12 @deckingman
                      @deckingman Thank you and everyone for their input.
