D2 Wifi network issues
Hi All,
Any thoughts on this? Wifi module doent ant to play ball...M552 s-1
WiFi module stopped
ok
M552 s0
ok
M552
WiFi module is being started
ok
M587
Failed to retrieve network list: another SPI transfer is pending
ok
M587 S"xxxx" P"xxxxx"
Error: M587: Failed to add SSID to remembered list: another SPI transfer is pending
ok
M552 s1
Turn off the current WiFi mode before selecting a new one
okJust trying to setup this Duet2 wifi for a new machine and network.
Looks to me like the wifi module isn't starting properly, it as OK last night but not now its installed in the printer.
Thoughts??
Many thanks
Barry M -
@CNCModeller try reflashing the wifi firmware using
M997 S1
@jay_s_uk said in D2 Wifi network issues:
M997 S1
m997 s1
Trying to connect at 230400 baud: failed
Trying to connect at 115200 baud: failed
Trying to connect at 74880 baud: failed
Trying to connect at 9600 baud: failed
Error: Installation failed due to comm write error
okNo dice unfortunately, any other thoughts?
@CNCModeller hmm, thats not a particularly good sign.
Did you sendM552 S0
first? -
Did you sendM552 S0
first?Yet another not good sign...
m552 s0
ok
WiFi module disabled - start timed out -
@CNCModeller if it won't go with
M552 S0
thenM997 S1
its probably a failed module -
M552 S0
thenM997 S1
its probably a failed moduleIs that something that can be fixed?
@CNCModeller replacing the ESP8266 usually fixes it
@CNCModeller said in D2 Wifi network issues:
So it was on wifi outside of the printer but now it's having issues? Have you tried removing it and testing it on the bench? Maybe a short?
@Phaedrux said in D2 Wifi network issues:
Yeah, the diagnostics above were out of the laser and back in the office, and I can't get any response. I replaced it in the laser with another Duet2 board and the replacement is working fine. Guess it's a dead wifi module as per the above diagnosis.
When and where was it purchased?
That's all in hand. The supplier has offered a replacement item. I'm not desperate for it as it's destined for upgrading my Wanhao D5s sometime in the near ish future.
Note to whoever repairs this board: yesterday I identified a QC issue with the soldering of the wifi module to the PCB on a different board variant. This is likely the same issue. Resoldering all the joints using no-clean flux, hotplate and fine-tipped soldering iron will probably fix this.
