    Wifi not working after Update of firmware( Duet 2 Wifi)
    Firmware installation
    • ajith_pinnintiundefined
      ajith_pinninti
      I've updated the firmware files through the Duet web interface. From after wifi is not blinking in powerup and not starting. I've changed the whole firmware with the old firmware that I used, It's not working again. I replaced the same SD card with another Duet, it's working as expected. But when I'm using that SD card in this Duet, wifi is not connecting.
      When I try to update the wifi details, it shows
      Wifi fails with "another SPI transfer pending.
      when I'm trying to update the firmware, it shows as below
      [20:26:15:626] Trying to connect at 230400 baud: success␊
      [20:26:21:404] Erasing 4096 bytes...␊
      [20:26:23:126] Erasing 196608 bytes...␊
      [20:26:38:127] Erase failed␊
      [20:26:38:127] Error: Installation failed due to timeout error␊
      Can you please guide me with, this? This happened to my two new Duet 2 wifi boards when I tried to update the firmware through the web interface.
      Thank you.
        Occasionally during the wifi firmware update the flash will fail silently. The solution is to send M997 S1 from the USB terminal to initiate a re-flash. This typically fixes it. Send that command and let me know what it does.
        ajith_pinnintiundefined 1 Reply Last reply Reply Quote 0
          ajith_pinninti @Phaedrux
          @Phaedrux
          When I sent that command I got this
          Note:- All the motors are moving as expected when I'm sending commands serially. Only wifi is not working
            jay_s_uk @ajith_pinninti
            @ajith_pinninti but did you send it again? thats just the same output that you posted in your first post
              ajith_pinninti @jay_s_uk
              @jay_s_uk Yeah, I tried again. Same thing happened.
                Please try sending this command sequence and report back what you get from each
                M552 S-1
                M552 S0
                M552 S1
                M997 S1
