    Pt1000/100 R value not working as expected
    STM
    • moth4017undefined
      moth4017
      Ver 3.5 b2
      if i connect a PT100
      M308 S1 P"F.8" Y"rtd-max31865" F50 R430
      this works
      if i connect a PT1000
      M308 S1 P"F.8" Y"rtd-max31865" F50 R4300
      This does not work value displayed in DWC 2000C
      If i connect a PT1000
      this works
      it seem the selecting R4300 for the PT1000 isnt working as expected
      • T3P3Tonyundefined
        T3P3Tony administrators @moth4017
        @moth4017 are you using a PT100 daughterboard? It has a reference resistor value of 400Ohms. Its designed for use with PT100 sensors and the MAX31865 chip requires a 4:1 ratio between reference resistors and nominal sensor resistance.
        This is only configurable to allow for other implementations of a MAX31865 circuit with a difference reference resistor to be used.
        Also, the pin name F8 does not look right so i guess this is not a Duet board?
        www.duet3d.com
        moth4017undefined 1 Reply Last reply Reply Quote 0
        • moth4017undefined
          moth4017 @T3P3Tony
          @T3P3Tony im using a octopus pro v1 , has the max 31865 on board.
          they use a ref 430R and a 4k3
          • T3P3Tonyundefined T3P3Tony moved this topic from Duet Hardware and wiring
          • T3P3Tonyundefined
            @moth4017 possibly @jay_s_uk can help then?
            www.duet3d.com
