    Connection 4 tools in mainboard
    My Duet controlled machine
    • UserXYundefined
      UserXY
      Hallo,
      ich verwende 4 Druckköpfe mit vier verschiedenen Tool Boards 1LC.
      Meine Mainboard ist das Duet3d 6HC.
      Leider kann ich nur drei Druckköpfe definieren.
      Zumindest sehe ich nur drei die ich auch steuern kann.
      Hier meine Config
      ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.15 on Fri Mar 03 2023 12:36:13 GMT+0100 (Mitteleuropäische Normalzeit)
      M575 P1 S1 B57600        ; enable support for PanelDue
      G90        ; send absolute coordinates...
      M83        ; ...but relative extruder moves
      M550 P"Schneider"        ; set printer name
      M669 K1        ; select CoreXY mode
      ; Wait a moment for the CAN expansion boards to start
      G4 S2
      M551 P"Schneider"        ; set password
      M552 P192.168.1.14 S1        ; enable network and set IP address
      M553 P255.255.255.0        ; set netmask
      M554 P192.168.1.254        ; set gateway
      M586 P0 S1        ; enable HTTP
      M586 P1 S1        ; enable FTP
      M586 P2 S0        ; disable Telnet
      M569 P0.0 S0 ;X - Achse        ; physical drive 0.0 goes backwards
      M569 P0.1 S0 ;Y - Achse        ; physical drive 0.1 goes backwards
      M569 P0.2 S0 ;Z - Achse 1        ; physical drive 0.2 goes backwards
      M569 P0.3 S0 ;Z - Achse 2																						; physical drive 0.3 goes backwards
      M569 P0.4 S1 ;Flies Spanner 1 																					; physical drive 0.4 goes forwards
      M569 P0.5 S1 ;Flies Spanner 2        ; physical drive 0.5 goes forwards
      M569 P1.0 S1 ;Flies Spanner 3																					; physical drive 1.0 goes forwards
      M569 P1.1 S1 ;Flies Spanner 4        ; physical drive 1.1 goes forwards
      M569 P1.2 S0 ;Kabelzug 1        ; physical drive 1.2 goes forwards
      M569 P2.0 S0 ;Kabelzug 2        ; physical drive 2.0 goes forwards
      M569 P2.1 S0 ;Kabelzug 3        ; physical drive 2.1 goes forwards
      M569 P2.2 S0 ;Kabelzug 4        ; physical drive 2.2 goes forwards
      M569 P121.0 S0        ; physical drive 121.0 goes forwards
      M569 P122.0 S0        ; physical drive 122.0 goes forwards
      M569 P123.0 S0        ; physical drive 123.0 goes forwards
      M569 P124.0 S1        ; physical drive 124.0 goes forwards
      M584 X0.0 Y0.1 Z0.2:0.3 A0.4 B0.5 C1.0 D1.1 U1.2 V2.0 W2.1 i2.1  E121.0:122.0:123.0:124.0                                           ; set drive mapping
      M350 X32 Y32 Z4:4  A16 B16 C16 D16 U16 V16 W16 i16 E16:16:16:16 I1                                                             ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z160.00:160.00  A400.0 B400.0 C400.0 D400.0 U80.0 V80.0 W80.0 i80.0 E100.00:100.00:100.00:100.00		                	; set steps per mm
      M566 X900.00 Y900.00 Z160.00:160.00  A120.0 B120.0 C120.0 D120.00  U120.0 V120.0 W120.0 i120.0  E120.0:120.00:120.00:120.00		                ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z280.00:280.0  A180.0 B180.0 C180.0 D180.0  U180.0 V180.0 W180.0 i180.0  E1200.00:1200.00:1200.00:1200.00				; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z200.00:200.00  A20.00 B20.0 C20.0 D250.00 U20.0 V20.0 W20.0 i20.0 E250.0:250.00:250.00:250.00			            ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800:800  A800 B800 C800 D800  U800 V800 W800 i800  E800:800:800:800 I90                                               ; set motor currents (mA) and motor idle factor in per cent
      M84 S30        ; Set idle timeout
      M208 X0 Y0 Z0 U0 V0 W0 A0 B0 C0 D0 S1        ; set axis minima
      M208 X850 Y850 Z400 U300 V30 W300 A300 B300 C300 D300 S0        ; set axis maxima
      M574 X1 S1 P"io1.in"        ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io2.in
      M574 Y1 S1 P"io2.in"        ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
      M574 Z1 S3 ;P"123.io0.in"        ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin io4.in
      M574 U1 S1 P"1.io4.in"
      M574 V1 S1 P"1.io5.in"
      M574 W1 S1 P"2.io0.in"
      M574 i1 S1 P"2.io1.in"
      M574 A1 S1 P"io5.in+io6.in"
      M574 B1 S1 P"io7.in+io8.in"
      M574 C1 S1 P"1.io0.in"
      M574 D1 S1 P"1.io2.in"
      M950 S18 C"121.io0.out"
      M558 P9 C"121.io0.in" H10 F20 T6000        ; disable Z probe but set dive height, probe speed and travel speed
      G31 P500 X0 Y0 Z1
      M557 X15:200 Y15:195 S20        ; define mesh grid
      ; Heaters	T:1000.0 B:3950.0 C:7.06e-8 R:2200.0 L:127 H:127
      ;T:1000.0 B:3950.0 C:7.06e-8 R:2200.0 L:0 H:-17
      M308 S0 P"temp1" Y"thermistor" T50000
      M950 H0 C"out0" Q10 T0        ; create bed heater output on out0 and map it to sensor 0
      M307 H0 R1.1 D30000 B0 S1.0        ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0 R30        ; map heated bed to heater 0
      M143 H0 S100        ; set temperature limit for heater 0 to 200C
      M308 S10 P"temp0" Y"PT1000" T1000  B3950 				                                                       ; configure sensor 10 as thermistor on pin temp0
      M308 S1 P"121.temp0" Y"thermistor" T100000         																	; configure sensor 1 as PT1000 on pin 121.temp0
      M950 H1 C"121.out0" T1                       																	; create nozzle heater output on 121.out0 and map it to sensor 1
      M307 H1 B0 S1.0        ; enable bang-bang mode for the bed heater and set PWM limit
      M143 H1 S250        ; set temperature limit for heater 0 to 200C
      M308 S2 P"122.temp0" Y"thermistor" T100000
      M950 H2 C"122.out0" T2
      M307 H2 B0 S1.0
      M143 H2 S250
      M308 S3 P"123.temp0" Y"termistor" T100000
      M950 H3 C"123.out0" T3
      M307 H3 B0 S1.0
      M143 H3 S250
      M308 S4 P"124.temp0" Y"termistor" T100000
      M950 H4 C"124.out0" T4
      M307 H4 B0 S1.0
      M143 H4 S250
      M308 S15 Y"mcu-temp" A"MCU"
      M950 F15 C"!out4" Q500  ;CPU Lüfter        ; create fan 0 on pin !out4 and set its frequency
      M106 P15 S10 T30 H15 C"CPU Lüfter Mainboard"        ; set fan 0 value. Thermostatic control is turned off
      M950 F16 C"2.out3" Q500        ; create fan 1 on pin !2.out3 and set its frequency
      M106 P16 S100 T30 H15 C"Board Lüfter"        ; set fan 1 value. Thermostatic control is turned off
      M950 F1 C"121.out1" Q250
      M106 P0 S1 H1
      M950 F2 C"122.out1" Q250
      M106 P0 S10 H2
      M950 F3 C"123.out1" Q250
      M106 P0 S10 H3
      M950 F4 C"124.out1" Q250
      M106 P0 S10 H4
      M950 F5 C"121.out2" Q250
      M106 P0 S10 H5
      M950 F6 C"122.out2" Q500
      M106 P0 S10 H6
      M950 F7 C"123.out2" Q500
      M106 P0 S10 H7
      M950 F8 C"124.out2" Q500
      M106 P0 S10 H8
      M563 P1 D1 H1 F1                               							    									; define tool 0
      G10 P1 X0 Y0 Z0                                    																; set tool 0 axis offsets
      G10 P1 R0 S0
      M563 P2 D2 H2 F2
      G10 P2 X0 Y0 Z0
      G10 P2 R0 S0
      M563 P3 D3 H3 F3
      G10 P3 X0 Y0 Z0
      G10 P3 R0 S0
      M563 P4 D4 H4 F4
      G10 P4 X0 Y0 Z0
      G10 P4 R0 S0
      M563 P5 D5 H5 F5
      G10 P5 X0 Y0 Z0
      G10 P5 R0 S0
      ; set initial tool 0 active and standby temperatures to 0C
      M950 P11 C"!Out1"
      M42 P11 S0
      ;Alle Achsen Freigen ohne Referenzfahrt
      M564 H0 S1	;Achsen Freigen
      G4 S1		;Wartezeit 1 Sekunden
      G91
      G1 Z15 		;Z - Achse 15mm nach oben fahren
      G92
      M564 H1 S1 	;Freigabe zurük nehemen
      M501        ; load saved parameters from non-volatile memory
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"                                                              ; set voltage thresholds and actions to run on power loss
      Hier das Web Interface.
      Kann mir da Jemand Helfen?
      Wie bekommen ich das fehlende 4 Tool angezeigt?
      Oder sind da grenzen gesetzt?
      Wo liegt der Fehler?
      I am using 4 print heads with four different tool boards 1LC.
      My mainboard is the Duet3d 6HC.
      Unfortunately I can only define three printheads.
      At least I only see three that I can control.
      Here is the web interface.
      Can someone help me?
      How do I get the missing 4 tool displayed?
      Or are there limits?
      Where is the error?
        jay_s_uk @UserXY
        @UserXY said in Connection 4 tools in mainboard:
        for starters, you should only have 1 set of Z values.
        you have 4 extruders mapped but your M563 lines start at D1 rather than D0.
        Best run M98 P"config.g" and see what errors get reported
        • UserXYundefined
          UserXY
          @jay_s_uk said in Connection 4 tools in mainboard:
          M563-
          He,
          vielen Dank ja das war mein Fehler den ich Langezeit gesucht habe.
          Vielen Dank
          • jay_s_ukundefined jay_s_uk marked this topic as a question
          • jay_s_ukundefined jay_s_uk has marked this topic as solved
          • UserXYundefined
            UserXY
            Könntest du mir noch bei dem Problem mit dem Temperatur Fühler helfen?
            Ich bekomme keine Messwerte bei beiden tool boards.
            Ich habe ein 103000 Ohmen gemessen bei Raumtemperatur es sind auch 100.000
            Ohmen Sensoren verbaut.
            Weißt du ein Rat wieso ich keine Messwerte er halte?
            Oder sind die tool borads kaputt?
              jay_s_uk @UserXY
              @UserXY your config looks correct. did you run M98 P"config.g"?
              please post an output from that.
              Also, a photo of your wiring on one of the boards would be good
              • UserXYundefined
                UserXY
                Hallo,
                ich habe den Fehler gefunden.
                Es hat sich ein tipp Fehler eingeschlichen.
                Ich habe das "h" bei Thermistor nicht geschrieben.
                M307 H2 B0 S1.0
                M143 H2 S250
                M307 H3 B0 S1.0
                M143 H3 S250
                Nun habe ich es verbessert und siehe da es Funktioniert perfekt.
                Vielen Dank für deine Hilfe.
                  jay_s_uk @UserXY
                  @UserXY great
