    G30 Question
    • JADoglioundefined
      JADoglio
      I built a Voron 2.4R2 using a klicky probe. I have a couple macros written to assist with Z offset calibration. I probe the bed using G30 3 times to get the height average for Z offset. The problem is every time I run G30 to get a measurement the firmware docks the klicky then undocks it takes a measurement, then docks and undocks the probe again for each subsequent probe. The macros are included. Is there a command that will just probe the bed without docking and undocking the probe ever time? Thanks
      The process starts with running the macro Z Offset Calibration in the macro file
      M561 ;clear Bed Mesh
      M568 P0 S240 ;set active temperatures for tool 0
      M140 S70 ;set Bed to 60C
      M116 S5 ;wait until bed 0 and tool 0 are up to temperature
      M564 S0 ;allow Z axis to exceed preset limits
      ; Home, but only if homing is needed
      if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
      G28
      G1 E-30 ;retract filament so nozzle does not ooze
      G1 Z55 F12000 ;raise Z axis 50mm for cleaning
      ;M291 P"Clean All Residue From Nozzle before setting Z0"
      M98 P"Clean Nozzle"
      G1 Z2
      G28
      M291 P"Use to pieces of paper and jog the nozzle down to the right tension on the bed" R"Press Ok when Done?" S3 X1, Y1, Z1 ;instruct user to manualy move nozzle to bed
      G92 Z0 ;Sets current location as Z0 Position
      M98 P"Z Offset Calibration Finish" ;Call Macro to finish job
      G90 ;set absolute
      G1 Z30 ;raise Z up 10 mm
      G30 S-1 ;(G30) home z (S-1) record z height
      G4 P1000 ;pause 1 sec
      G1 X175 Y175 ;move Hot End to X175 Y175
      M291 P"Check Consul for Results of Probing " ;instruct user to check results in Consol
      ;G28
      chrishammundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
      • chrishammundefined
        chrishamm administrators @JADoglio
        @JADoglio At present G30 always deploys/retracts the probe because that's required to drive a BLTouch and possibly other probes. Perhaps it would make more sense to define your Z-probe as a second tool and to do the dock/undock procedures in the corresponding tpre/tfree.g.
        Duet software engineer
        JADoglioundefined 1 Reply Last reply Reply Quote 0
          jay_s_uk @JADoglio
          @JADoglio you could send M401 before running any G30's and then M402 when finished. This should override the deploy for the G30
          JADoglioundefined 1 Reply Last reply Reply Quote 1
          • JADoglioundefined
            JADoglio @chrishamm
            @chrishamm Thanks I will investigate.
            • JADoglioundefined
              JADoglio @jay_s_uk
              @jay_s_uk Again, thanks I will play with this as well
              • JADoglioundefined
                JADoglio @JADoglio
                @JADoglio I tried the 401/402 option first since it seemed simpler than creating another tool which I suspect would have also worked. This option worked as expected. Problem solved, Thanks
