PanelDue Firmware 3.5.0-rc1 released
Hallo,
a new version of PanelDue Firmware was build and released.
This is still a release candidate which means it is not officially declared stable. So if you find any bugs please report them here in this thread.
Otherwise enjoy peaceful printing...
Firmware images and release notes can be found on github. Just follow the link below.
https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.5.0-rc1
@mfs12
I've installed this on a machine that's running RRF 3.5.0b2 on the mainboard/toolboard and DWC 3.5.0-b3.And
M291 S2
messages don't show the "OK" button. Don't know if this is a bug or a if it's because i'm running 3.5b2 instead of 3.5b3 on the mainboard?M291 S3
Works as one would suspect and display both "OK" & "Cancel". -
A couple more bugs on M291
Testing on
RRF 3.5beta3
HW MB6HC
PanelDue HW V3 7inch (Fysetc)-
The message box title displays the R value from the previous M291 command (even if it was in a different macro). Verified with S = 0,1,2 but didn't test on other modes.
If S = 1, there is no CLOSE button, but there is window close button ("X" in the corner). - reported by @Exerqtor
If S=2, there is no OK button, but there is window close button ("X" in the corner). If T=0, the X will close the window but does not unblock execution. An INFO message is added to the eventlog saying "M292: cancelled=false"
@Exerqtor said in PanelDue Firmware 3.5.0-rc1 released:
And M291 S2 messages don't show the "OK" button. Don't know if this is a bug or a if it's because i'm running 3.5b2 instead of 3.5b3 on the mainboard?
hm... i think this how it was before. I tried not to change the old behavior.
@mikeabuilder said in PanelDue Firmware 3.5.0-rc1 released:
ok, will check this.
@mfs12 If the error message comes that he cannot extrude because the heater is not on, there is no way to close the box
@mfs12
Naaah earlier it would show the "OK" button on both DWC and PD withS2 😅
found the bugs mode and title problem... the title thing was there since a long time but occured only in certain circumstances.
@Proschi78 please be more specific how to reproduce the bug.
but eventually with the fixes it's already fixed. so best probably to wait for the next RC and test again.
@mfs12 I called stop.g to test something. There I have a filament retraction of 3mm. Because the extruder was not heated, the error message came up. There is no ok or cross to close the box
@mfs12 - Thanks for your work getting the beta FW released and the quick response to these new items. I don't know how much effort it is to do a new beta, but the lack of ability to close a blocking S=2 message is pretty bad and it would be great if a new beta addressing that issue is available soon.
Hope that doesn't sound too pushy. I'm really looking forward to upgrading my printer user interface with the new M291 capabilities.
new release out. this thread is closed.
https://forum.duet3d.com/topic/32204/paneldue-firmware-3-5-0-rc2-released
undefined mfs12 locked this topic
