    Flagged as Spam??
    475
    • gumbyundefined
      gumby @gumby
      @gumby
      But cannot find a maximum declared anywhere.
      Is this something common? I have tried all the suggestions I could find, like the second to last command dropping 15mm instead of 5, but that didn't seem to help
      Thanks for any wisdom on this issue.
      Gumby
      • gumbyundefined
        gumby @gumby
        @gumby
        Okay, I posted the same words in three separate chunks and none of them got flagged. Maybe the post was too long??
        Just info for anyone that may be experiencing the same thing...
        Gumby
          You've had a few upvotes now and some successful posts. It may ease up on you now.
          As for your issue, please share your config and homing files etc.
          Also please share the results of M122 and M98 P"config.g"
          You may have to fit those into a few posts due to length.
          gumbyundefined 1 Reply Last reply Reply Quote 0
            Actually I see your other thread now. You can post your info there.
            • gumbyundefined
              gumby @Phaedrux
              @Phaedrux
              I will respond to this in the post with the issue (Firmware)
              My M98 response was M98: No P or R parameter
                The full command is M98 P"config.g"
                • br7408undefined
                  br7408
                  I'm having the same issue. My post keeps getting flagged as spam.
                  br7408undefined 1 Reply Last reply Reply Quote 2
                  • br7408undefined
                    br7408 @br7408
                    @br7408 said in Flagged as Spam??:
                    I tried posting from a different computer and it works now. Wierd.
                    • gumbyundefined
                      gumby @Phaedrux
                      @Phaedrux said in Flagged as Spam??:
                      M98 P"config.g"
                      Sorry for the delay. I have had a busy weekend.
                      I am not sure what to expect. I looked up M98 and it is the subroutine call. So I don't know where to look or what to expect.
                      I reviewed the console and here is what it says...
                      Is that what you were expecting, or am I missing something?
                      Thanks,
                      Gumby
                        Let's continue in your other thread. this one is about being flagged as spam afterall.
