Config BLTouch on Duet2 for Z Homing
I have just finishing a CoreXY D-Bot controlled by a Duet2 Ethernet with no expansion boards. I have the BLTouch installed so that it has an X offset of -23. At X0, the BLTouch is not over the bed, it is maybe 15mm from the edge.
I have two questions.
On the Reprap config tool page for drives, what endstop pin option do I select for the Z drive (Z-Stop, Z-Stop (Active-Low), Z-Stop (Pull-up), Z-Stop (Active-Low, Pull-up)?
Can I use the BLTouch for Z Homing even though at X0 it is not over the bed?
Sorry for the noob questions. I went through about 20 pages of a search for BLTouch and didn't find the answer.
I am currently using a Ordbot Hadron I built 10 years ago and have always run repetier firmware so this is my first reprap machine.
@flyboy369
to 1.
select not assigned
to 2.
Yes, that is possible and not unusual.
The homing of the axes happens first for X and Y and then for Z.
For the homing of Z the printhead usually is moved to the center of the bed.
But this needs to be adjusted later in the homing files.
As far as i have seen in the config tool the head is only moved until the sensor is at the edge of the print area.
It is important that the offset for the sensor is specified correctly. -
@DIY-O-Sphere Thanks for the help. I will get it wired up tomorrow and see about getting the config fixed up.
Post your homing files and config.g if you want a sanity check.
It would help to know your firmware version as well. -
@Phaedrux Got it wired up tonight and it passes the static test.
Here is the config.g
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.16 on Sat Apr 29 2023 09:58:12 GMT-0700 (Mountain Standard Time); General preferences
M550 P"TroysDBot" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M350 Z4 I0 ; configure microstepping without interpolation
M350 X16 Y16 E16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X320 Y278 Z250 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!^xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !^xstop
M574 Y1 S1 P"!^ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !^ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
G31 P500 X-23 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:300 Y15:270 S20 ; define mesh grid; Heaters
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@Phaedrux Here is the homex.g
; homex.g
; called to home the X axis
G91 ; relative positioning
G1 H1 X-325 F3000 ; move quickly to X axis endstop and stop there (first pass)
G1 X5 F6000 ; go back a few mm
G1 H1 X-325 F360 ; move slowly to X axis endstop once more (second pass)
G1 H2 Z-5 F6000 ; lower Z again
G90 ; absolute positioningHomey.g
; homey.g
; called to home the Y axis
G1 H1 Y-283 F3000 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y5 F6000 ; go back a few mm
G1 H1 Y-283 F360 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioningHomez.g
; homez.g
; called to home the Z axis
G1 X38 Y15 F6000 ; go to first probe point
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioningHomeall.g
; homeall.g
; called to home all axes
G1 H1 X-325 Y-283 F3000 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-325 ; home X axis
G1 H1 Y-283 ; home Y axis
G1 X5 Y5 F6000 ; go back a few mm
G1 H1 Y-283 ; then move slowly to Y axis endstop
G1 X38 Y15 F6000 ; go to first bed probe point and home Z
;G90 ; absolute positioningThanks for the help.
@flyboy369 said in Config BLTouch on Duet2 for Z Homing:
Remove that line from the config.g
Check the endstop settings
usually the look like thisM574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
Check the microstepping for Z
M350 Z4 I0 ; configure microstepping without interpolation<
In the homez.g and in homeall.g
changeG1 X38 Y15 F6000 ; go to first probe point<
to
G1 X183 Y139 F6000 ; go to first probe point
That should be the center....
@DIY-O-Sphere Thanks! Made the changes and will try to finish the bltouch calibration today.
@flyboy369 Got it working. Thanks for all of the help. I was able to do an initial mesh compensation map as a test.
