    Active Codes
    Duet Web Control
    • gumbyundefined
      gumby
      I have a CNC machine that shows the active codes for the machine.
      i.e. absolute/relative, pump on/pump off/ compensation, etc.
      I really like having that info and I was wondering if that existed in the interface, or how to poll the machine for that info.
      Thanks in advance.
      Gumby
        dc42 administrators @gumby
        @gumby most of this information is available from the Object Model. See https://docs.duet3d.com/en/User_manual/RepRapFirmware/Object_Model to get started.
          You can check the object model.
          Are you wanting to show that info in DWC?
          Maybe something like DueUI could be used to give you something more customized.
          https://forum.duet3d.com/category/33/dueui
          oliofundefined gumbyundefined 2 Replies Last reply Reply Quote 1
          • oliofundefined
            oliof @Phaedrux
            @Phaedrux or BtnCmd plugin for DWC
            • gumbyundefined
              gumby @Phaedrux
              Thank you everyone,
              I will look into all of that info.
              Cheers,
              Gumby
