Solved Input Shaping plugin not collecting data using 3.5.0-beta.3
@omni Thanks for that you are correct. Much easier than going back to DWC 3.4.5.
Just refreshing the profiles in the Motion Analysis tab brings up the latest run.
However no matter what Input Shaper function or damping factor I apply the graphs are all pretty similar. I am not sure the data is valid. Also, in the Profile description it says 1 move but I asked for two. It always used to say 2 moves.
I agree it is probably a small bug and will go away in the next release.
@tas There is another problem in v3.5-b3 affecting filename parsing of newer profiles, but that is about to be fixed in 3.5-b4. I've also added new code to auto-remove the old IS plugin if it is still installed.
@chrishamm Many thanks for that excellent support. I knew you would be on top of it.
@tas This problem has now been solved by @chrishamm. Refer to this post by @alexjx
Go down to the google drive link provided.
Thanks for the combined effort @chrishamm, @droftarts, and @jay_s_uk. Also thanks to @alexjx for zeroing in on the problem so it could be solved.
