    Input Shaping plugin not collecting data using 3.5.0-beta.3
    Beta Firmware
    906
    • tasundefined
      tas @chrishamm
      @chrishamm I have checked the wiring on both printers and the modules have all wires connected. Both printers worked before with Input Shaping with the LIS3DH modules attached to them.
      I removed one module from the printhead and placed it beside the printer. From the PanelDue console I ran M956 P0 S5000 A0.
      A csv file was recorded in the System>Accelerometer folder. It had 5000 samples.
      I then ran the Record Motion Profile from DWC with the following settings:
      and got this result:
      There was a file recorded with about 1000 samples: (Ignore the actual values recorded as the accelerometer is on the table, not on the printhead)
      1-X55-170-0-none.csv
      I am not sure what to check next. Any help greatly appreciated.
      • ctilley79undefined
        ctilley79 @chrishamm
        @chrishamm said in Input Shaping plugin not collecting data using 3.5.0-beta.3:
        @dc42 Right, the display is off then because there are two arrays of loaded plugins, one for integrated and another one for external plugins. But it should have loaded the correct integrated DWC plugin nevertheless.
        I'll make sure the external Input Shaping plugin is automatically uninstalled in the next beta.
        I had this same issue. I had weird behavior and seemed to have two versions of the input shaper plugin installed. I had to delete all and start from scratch.
        tasundefined 2 Replies Last reply Reply Quote 0
        • tasundefined
          tas @ctilley79
          @ctilley79 Thanks. I will give that a try now.
          • tasundefined
            tas @ctilley79
            @ctilley79 I went back to 3.4.5 and installed the external Input Shaping plugin.
            Everything worked as expected and I was able to gather data normally.
            I reupgraded to 3.5.0-beta.3 and I get "Data collection cancelled" again.
            • OwenDundefined
              OwenD
              Duet 2 WiFi 3.5.0-beta.3+
              Duet WiFi Server 2.1beta4
              Duet Web Control 3.5.0-beta.3
              I get the same thing.
              I deleted the external plugin. Cleared the cache and refreshed DWC
              What I do note is that the file is actually recorded, but it isn't visible in the plugin motion analysis
              See screen capture
              • tasundefined
                tas @OwenD
                @OwenD Thanks. At least I am not going crazy.
                I did notice there are files being created but I am not sure if they are valid.
                I got the same thing with 3.5.0-beta.3 and 3.5.0-beta.3+.
                • tasundefined
                  tas @OwenD
                  @OwenD @chrishamm @dc42 I decided to look further into the files and you are absolutely correct @OwenD. The csv files are there and they appear to be valid, they just don't show up.
                  I found a workaround. If you install DWC 3.4.5 then the external input shaping plugin, v3.4.1-b1 the input shaping works as expected and all of your files will be revealed. You can do more tests without errors.
                  omniundefined 1 Reply Last reply Reply Quote 0
                  • omniundefined
                    omni @tas
                    @tas I am having the same problem, and I uninstalled the external plugin. But I found a workaround without going back to the old external plugin - just click the refresh icon on the profiles list and they will appear. I too get a message that it was not recorded, but in fact it was, it's just a small bug probably.
                    tasundefined 1 Reply Last reply Reply Quote 0
                    • tasundefined
                      tas @omni
                      @omni Thanks for that you are correct. Much easier than going back to DWC 3.4.5.
                      Just refreshing the profiles in the Motion Analysis tab brings up the latest run.
                      However no matter what Input Shaper function or damping factor I apply the graphs are all pretty similar. I am not sure the data is valid. Also, in the Profile description it says 1 move but I asked for two. It always used to say 2 moves.
                      I agree it is probably a small bug and will go away in the next release.
                      • chrishammundefined
                        chrishamm administrators @tas
                        @tas There is another problem in v3.5-b3 affecting filename parsing of newer profiles, but that is about to be fixed in 3.5-b4. I've also added new code to auto-remove the old IS plugin if it is still installed.
                        Duet software engineer
                        tasundefined 1 Reply Last reply Reply Quote 2
                        • tasundefined
                          tas @chrishamm
                          @chrishamm Many thanks for that excellent support. I knew you would be on top of it.
                          • tasundefined tas referenced this topic
                          • alexjxundefined alexjx referenced this topic
                          • tasundefined
                            tas @tas
                            @tas This problem has now been solved by @chrishamm. Refer to this post by @alexjx
                            https://forum.duet3d.com/topic/32762/3-5b4-input-shaping-plugin-bug-data-collection-cancelled/13?_=1687311263398
                            Go down to the google drive link provided.
                            Thanks for the combined effort @chrishamm, @droftarts, and @jay_s_uk. Also thanks to @alexjx for zeroing in on the problem so it could be solved.
                            • droftartsundefined droftarts marked this topic as a question
                            • droftartsundefined droftarts has marked this topic as solved
