Problems with WIFI in Duet 3 Mainboard 6HC
we bought in E3D-Online a Duet 3 Mainboard 6HC and WIFI stops working after a few months, started to lost the configuration of wifi and now we can't make it work anyway.
It's updated to the latest firmware and we can't make wifi works, see photo.
Anny suggestions?
Thanks
@Duncan if it's starting up in SBC mode that means the SD card isn't being read at startup.
@Duncan From the M115, it's a Mini 5+, not a 6HC. As @dc42 says, most likely it is not reading the SD card, so the Duet assumes it is connected to a Raspberry Pi.
See the following troubleshooting section: https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card
Try a fresh SD card, following the instructions further up the page of the link above to format and setup the card for Duet. If that doesn't help, take a picture of the area around the SD card slot on the Duet board; we have had a few boards that have had component failures in this area, though it is rare.
Hello again,
thank you so much, we just follow all the steps and WIFI is working again.Thanks
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
