    motors keep running after hitting stop switch when homing
    homing motors limit switch
    • meepkittydoktorundefined
      meepkittydoktor
      I am using the mini5+ wifi , rev 1.01. latest stable RRF.
      I am setting up my first DIY printer and I have everything wired together and I am at the stage where I am just testing the operation of each part.
      I have this wierd issue where when homing any axis, the motor will keep running after hitting the limit switch, then it will stop moving but I can hear some sort of high frequency noise indicating the motor is still receiving power. It does not stop after a few seconds and I do not feel comfortable allowing more time to to pass so I turn off the power and cannot tell if it will stop after many seconds. Can someone please explain to me what it's doing?
      My configuration is as follows:
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.16 on Tue May 16 2023 12:11:52 GMT-0400 (Eastern Daylight Time)
      M550 P"meeprint"                                   ; set printer name
      M551 P"Password1!"                                 ; set password
      ;M569 P0.4 S1                                       ; physical drive 0.4 goes forwards
      ;M569 P0.3 S1                                       ; physical drive 0.3 goes forwards
      ;M569 P0.2 S1                                       ; physical drive 0.2 goes forwards
      ;M569 P0.1 S1                                      ; physical drive 0.1 goes forwards
      M569 P0.4 S0                                       ; physical drive 0.4 goes backwards
      M569 P0.3 S0                                       ; physical drive 0.3 goes backwards
      M569 P0.2 S0                                       ; physical drive 0.2 goes backwards
      M569 P0.1 S0                                       ; physical drive 0.1 goes backwards
      M584 X0.4 Y0.3 Z0.2:0.0 E0.1                       ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E932.00                  ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00            ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
      M208 X300 Y300 Z400 S0                             ; set axis maxima
      ;M574 X1 S1 P"!io5.in"                              ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !io5.in
      ;M574 Y1 S1 P"!io6.in"                              ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !io6.in
      ;M574 Z1 S1 P"!io2.in"                              ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin !io2.in
      M574 X1 S1 P"io5.in"                              ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io5.in
      M574 Y1 S1 P"io6.in"                              ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io6.in
      M574 Z1 S1 P"io2.in"                              ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin io2.in
      M558 P5 C"^io3.in" H5 F120 T6000                   ; set Z probe type to switch and the dive height + speeds
      G31 P500 X0 Y0 Z2.5                                ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20                           ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138       ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"temp1" Y"thermistor" T100000 B4138       ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
      M143 H1 S500                                       ; set temperature limit for heater 1 to 500C
      M950 F0 C"out3" Q500                               ; create fan 0 on pin out3 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"out4" Q500                               ; create fan 1 on pin out4 and set its frequency
      M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"out5" Q500                               ; create fan 2 on pin out5 and set its frequency
      M106 P2 S1 H0 T45                                  ; set fan 2 value. Thermostatic control is turned on
      M501                                               ; load saved parameters from non-volatile memory
      droftartsundefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @meepkittydoktor
        @meepkittydoktor
        First, test your endstops work; see https://docs.duet3d.com/en/How_to_guides/Commissioning#h-8-check-endstops
        Then check at which end of each axis each endstop is located. When you look at your printer, usually the origin (where X=0 and Y=0) is in the front left of the machine. If the endstop is close to the axis zero (eg X0 and/or Y0), it is a minimum endstop. M574 commands should have the axis with a '1' for a minimum axis, eg M574 X1 .... If the endstop is close to the axis maximum (X300 and/or Y300 in your case) it is a maximum endstop, and M574 commands should have the axis letter with a '2' for a maximum axis, eg M574 X2 .... See https://docs.duet3d.com/en/How_to_guides/Commissioning#h-9-re-configure-endstops
        Check that your motors run in the correct direction. When you look at your printer, usually the origin (where X=0 and Y=0) is in the front left of the machine. Moving the X axis positively should move the nozzle to the right, and moving the Y axis positively should move the nozzle backwards relative to the bed (ie move the nozzle back on a machine with a bed that moves in Z only and nozzle moving in X and Y, or bed moves forward if bed moves in Y and nozzle moves in X and Z). If they are not moving as expected, change the M569 command for the motor that is moving the wrong direction. See https://docs.duet3d.com/en/How_to_guides/Commissioning#h-10-check-stepper-motors
        If you have changed any of these, you may need to change the homing gcode macros homex.g, homey.g, homez.g and homeall.g. If you still have problems, post them and your updated config.g.
        • gloomyandyundefined
          gloomyandy @meepkittydoktor
          @meepkittydoktor We need to see your homing file(s) for whichever axis you are having problems with (so homx.g, homey.g and possibly homeall.g). See: https://docs.duet3d.com/User_manual/Connecting_hardware/Sensors_endstops
          https://docs.duet3d.com/User_manual/Machine_configuration/Configuration_cartesian#homing-files
            meepkittydoktor
            Ah ok so the problem was that I forgot to declare the second Z stepper and only mapped it, and I got turned around wiring the motors and endstops and had to reverse a few things. I also was taught that the whining noise is normal and can be stopped with "stealth chop" by putting D3 V40 after the drive declaration. I.E. M569 P0.0 S1 D3 V40
            Thank you for the help!
            Now I just have to figure out why the extruder thermistor is reading 314C and why the bed heater is faulting lmao
