Delta move axis independent from cartesian coordinates?
is it possible to move the axes of a Delta printer independently of the Cartesian coordinates? I mean that I enter a gcode command like G0 X10, by default it would now move 10 mm in the X direction and move the linear slides, but I would like to control the motors directly and say G? Motor_1 10 and then the motor moves 10 mm.
Is there a solution for this?Best regards
Tim -
G1 H2 option
just check on https://docs.duet3d.com/User_manual/Reference/Gcodes#g1-controlled-linear-move
@tkln yes, use the H2 parameter on the G1 command.
undefined tkln has marked this topic as solved
@apak
Thank you for the solution.
