    how to get two stepper motors to work together
    313
    • gardon64undefined
      gardon64
      hi all can anyone help me with how to get two stepper motors to work together on y axis
      duet 3 6xd
        droftarts administrators @gardon64
        @gardon64 see https://docs.duet3d.com/User_manual/Connecting_hardware/Motors_configuring#using-more-than-one-motor-on-an-axis-with-a-separate-driver-for-each-motor
        • gardon64undefined
          gardon64
          NOW I GET
          Error: M569: Response timeout: CAN addr 1, req type 6018, RID=3 HELP?
          • gardon64undefined
            gardon64
            HEAR IS CONFG .G
            Configuration file for Duet 3 MB 6XD (firmware version 3.3)
            ; generated by RepRapFirmware Configuration Tool v3.3.16 on Thu May 25 2023 12:31:46 GMT+0100 (British Summer Time)
            M453
            M550 P"Duet 3 CNC" ; set printer name
            M569 P0.1 S0 ; physical drive 0.1 goes backwards
            M569 P0.2 S0 ; physical drive 0.2 goes backwards
            M569 P1.0 S1 ; physical drive 1.0 goes forwards
            M584 X0.0 Y0.1:O.2 Z0.2 E0.3 ; set drive mapping
            M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
            M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
            M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X230 Y0210 Z200 S0 ; set axis maxima
            ; WARNING: No endstops configured
            M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
            M557 X15:215 Y15:195 S20 ; define mesh grid
            M140 H-1 ; disable heated bed (overrides default heater mapping)
            M563 P0 D0 F0 ; define tool 0
            • g.bielundefined
              g.biel
              Fail . Y0.2 and Z0.2
              E P1.0 ?? no E0.3 ?
              • gardon64undefined
                gardon64
                Error: M569: Response timeout: CAN addr 1, req type 6018, RID=7
                still this error
                  Can you see something off there?
                  You have the letter O instead of the number zero on the Y axis mapping.
                  • gardon64undefined
                    gardon64
                    Thank you all working now
