    Reboots/resets randomly - RRF 3.5.0-b4
    Beta Firmware
    12
    112
    7.3k
      dc42 administrators @RogerPodacter
      @RogerPodacter thanks.
      • Please also provide your homing files, since you said the machine resets during homing.
      • Although this doesn't explain the reset, I can see a problem in your config.g file. Your M669 command to set the kinematics at line 7 refers to the U axis, however the U axis doesn't exist until it is created in the M584 command at line 35. You should move the M669 command to be after the M584 command.
      Exerqtorundefined 1 Reply Last reply Reply Quote 1
      • Arminasundefined
        Arminas @dc42
        This post is deleted!
        • Exerqtorundefined
          Exerqtor @dc42
          Just as a little update, i have as of today not had any more resets. I'm trying to turn out some small parts, just to see if anything can trigger a reset, but so far no luck =/
            dc42 administrators @Exerqtor
            @Exerqtor thanks for the update. I have not yet had a reset either using your files or the file from @RogerPodacter (although I am still waiting for his homing files, and he reported that the reset occurred when homing).
            RogerPodacterundefined Exerqtorundefined 2 Replies Last reply Reply Quote 0
            • RogerPodacterundefined
              RogerPodacter @dc42
              @dc42 apologies for the delay. here are my homing files. my printer kinematics didnt work correctly, so i dont know if that was related while i was attempting the homings...
              homeall.g
              if (move.axes[0].homed && move.axes[1].homed && move.axes[2].homed && move.axes[3].homed)
              	echo "already homed, skipping"
              else
              	;T0
              	G91																	; Relative positioning
              	G1 Z15 F6000 H2														; Lift Z relative to current position
              	G1 Y999 F3000 H1												; Move X and Y-axes to the endstops and stop (first pass)
              	G1 Y-4 F600														; Move Y-axis to the endstop and stop (first pass)
              	G1 Y15 F600 H1														; Move X-axis to the endstop once more (second pass)
              	G1 X-999 F3000 H1 										; coarse home X, Y and U
              	G1 X4 F600 												; move 4mm away from the homing switches
              	G1 X-15 H1     												; fine home X, Y and U
              	G1 U999 F3000 H1 										; coarse home X, Y and U
              	G1 U-4 F600 												; move 4mm away from the homing switches
              	G1 U15 H1     												; fine home X, Y and U
              	G90																	; Absolute positioning
              	M401 ; deploy Z probe (omit if using bltouch)
              	; Home Z using the Z-Probe
              	M290 R0 S0															; Reset baby-stepping to 0
              	G1 X183 Y170 F6000											; Move T0 to probing point (X150, Y150), including probe offset
              	G30																	; Probe the bed and set Z to the probe offset
              	M402 ; retract probe (omit if using bltouch)
              homex.g
              M201 X500.00 U500.00    ; Reduce acceleration for homing moves
              G1 H2 Z5 F6000          ; Lift Z relative to current position
              G1 H1 X-625 F3000       ; Move quickly to X endstop and stop there (first pass)
              G1 X3 F600              ; Go back a few mm
              G1 H1 X-625 F360        ; Move slowly to X endstop once more (second pass)
              ;G1 H1 U625 F1800
              ;G1 U-3 F600
              ;G1 H1 U625 F360
              M201 X3000 U6000        ; Return to full acceleration
              G1 H2 Z-5 F6000         ; Lower Z relative to current position
              homey.g
              M201 X500.00 Y500.00    ; Reduce acceleration for homing moves
              G1 H1 Y605 F3000        ; Move quickly to Y endstop and stop there (first pass)
              G1 Y-3 F600             ; Go back a few mm
              G1 H1 Y605 F360         ; Move slowly to Y endstop once more (second pass)
              M201 X3000 Y6000        ; Return to full acceleration
              homez.g
              ; Euclid Probe homez.g Example Macro
              ; RRF3.X Firmware Example
              ; saveas system/homez.g
              ; comments and echo statements throughout are provided for convenience
              if !move.axes[0].homed || !move.axes[1].homed     ; If the printer hasn't been homed, home it
              	M98 P"0:/sys/homexy.g"
              M561                                            ; clear any bed transform
              M290 S0 R0                                      ; clear baby steps
              G91                                             ; relative positioning
              G1 H2 Z15 F6000                                  ; lift Z relative to current position to clear any obstructions
              M400
              G1 U380 F2000 ; make sure the U carriage is out of the way
              G90                                             ; absolute positioning
              ; echo "Call deployprobe.g macro"
              M401 P0                                         ; This runs macro file deployprobe
              ; echo "Return"
              G1 X155 Y155 F9000                            ; go to center of bed in advance of probe that point
              M400
              ; echo "G30 Command"
              G30                                             ; Probe the bed at the current XY position. When the probe is triggered,
                                                              ; adjust the Z offset of the current tool to make the current position Z=0.
              ;G1 Z10                                          ; raise Z=10
              ;M400
              ;G4 P500
              ; echo "Call bed4point.g macro"
              ;M98 P"0:/sys/bed.g"                       ; tram bed
              ; echo "Return"
              ;G1 X145 Y162.5 F9000                              ; go back to the first probe point and reprobe 0 in case it moved
              ;G30
              ; echo "Call retractprobe.g macro"
              M402 P0                                         ; retract probe
               echo "Return"
              ;G1 Z10 F600                                     ; lift Z relative to current position
              M564 S1 H0                                      ; reset the bounding limits
              ; G1 X150 Y0 F9000                              ; move carriage to center front
              homeu.g
              M201 U500.00 Y500.00    ; Reduce acceleration for homing moves
              G1 H1 U625 F3000       ; Move quickly to X endstop and stop there (first pass)
              G1 U-3 F600              ; Go back a few mm
              G1 H1 U625 F360        ; Move slowly to X endstop once more (second pass)
              M201 U3000 Y6000        ; Return to full acceleration
              bed.g
              M290 R0 S0    ;  clear baby stepping
              M561          ;  reset all bed adjustments
              M400          ;  flush move queue
              ; echo "Running bed4point.g"
              ;M558 F60 A6 ;A3                              ; fix probe speed to 1mm/s
              ;G90
              ;G4 P250
              if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
              	echo "not all axes homed, homing axes first"
              	G28
              G30 P0 X46 Y20 Z-99999 ; X41 X30 Y20 Z-99999 ; probe near a leadscrew
              G30 P1 X155 Y276 Z-99999 ;Y282 Z-99999 ; probe near a leadscrew
              G30 P2 X270 Y20 Z-99999 S3 ; probe near a leadscrew and calibrate 3 motors
              echo "Current rough pass deviation: " ^ move.calibration.initial.deviation
              while move.calibration.initial.deviation > 0.005
              		if iterations >= 5
              			echo "Error: Max attemps failed. Deviation: " ^ move.calibration.initial.deviation
              			break
              		echo "Deviation over threshold. Executing pass" , iterations+1, "deviation", move.calibration.initial.deviation
              		G30 P0 X46 Y20 Z-99999 ; probe near a leadscrew
              		G30 P1 X155 Y276 Z-99999 ; probe near a leadscrew
              		echo "Current deviation: " ^ move.calibration.initial.deviation
              		continue
              echo "Final deviation: " ^ move.calibration.initial.deviation
              G0 X155 Y155 Z20 F9000
              G30
              ;G28 Z
              • Exerqtorundefined
                Exerqtor @dc42
                After a couple days without any resets, it happend again twice yesterday:
                power up + 00:00:03 [info] Event logging started at level debug
                power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-beta.4 (2023-06-08 23:40:14)
                power up + 00:00:03 [debug] Done!
                power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running.
                power up + 00:00:04 [warn] WiFi module started
                power up + 00:00:07 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.50
                power up + 00:00:09 [warn] HTTP client 192.168.10.100 login succeeded (session key 1366409378)
                2023-06-16 01:23:20 [warn] Date and time set at power up + 00:00:09
                power up + 00:00:08 [warn] HTTP client 192.168.10.100 login succeeded (session key 125510966)
                2023-06-16 10:24:14 [warn] Date and time set at power up + 00:00:08
                m122
                RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.4 (2023-06-08 23:40:14) running on Duet 3 Mini5plus WiFi (standalone mode)
                Board ID: FAP55-Q967A-G65J0-401GL-0S02Z-RF9TL
                Used output buffers: 1 of 40 (30 max)
                Static ram: 102996
                Dynamic ram: 124208 of which 16 recycled
                Never used RAM 11980, free system stack 180 words
                Tasks: NETWORK(2,nWait,126.9%,219) HEAT(3,nWait,0.5%,327) Move(4,nWait,0.1%,344) CanReceiv(6,nWait,1.1%,672) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.2%,351) TMC(4,delaying,26.0%,108) MAIN(1,running,48.1%,704) IDLE(0,ready,8.9%,29) AIN(4,delaying,18.0%,266), total 229.7%
                Owned mutexes:
                Last reset 26:40:40 ago, cause: software
                Last software reset at 2023-06-16 10:24, reason: HardFault invState, Gcodes spinning, available RAM 10580, slot 1
                Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011fa8 Task NETW Freestk 482 ok
                Stack: 000001ae 00000002 200014ec 00000000 2003335a 0009d43d 00000000 600f0000 00000000 00000000 00000000 00000000 20032174 00000800 20035e68 2002c558 20018670 2002c3f5 20018670 2001e920 0002fe6f 00000000 00000000 00000000 20012058 00000014 b5ddc1d1
                Error status: 0x00
                Aux0 errors 0,0,0
                MCU revision 3, ADC conversions started 96040137, completed 96040137, timed out 0, errs 0
                MCU temperature: min 35.1, current 36.3, max 39.4
                Supply voltage: min 23.7, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
                Heap OK, handles allocated/used 99/28, heap memory allocated/used/recyclable 2048/980/596, gc cycles 3588
                Events: 0 queued, 0 completed
                Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 33, reads 14596, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 33, reads 14596, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 147, reads 14596, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 147, reads 14595, writes 13, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6c
                Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 150, reads 14595, writes 13, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6a
                Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 43, reads 14597, writes 10, timeouts 2, DMA errors 0, CC errors 0, failedOp 0x6a
                Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 43, reads 14599, writes 10, timeouts 0, DMA errors 0, CC errors 0
                Date/time: 2023-06-17 13:04:45
                Slowest loop: 22.78ms; fastest: 0.14ms
                === Storage ===
                Free file entries: 18
                SD card longest read time 4.5ms, write time 4.2ms, max retries 0
                DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
                no step interrupt scheduled
                === DDARing 0 ===
                === DDARing 1 ===
                Heater 1 is on, I-accum = 0.0
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                SBC is idle in state(s) 0
                Daemon is doing "G4 S1        " in state(s) 0 0, running macro
                Aux2 is idle in state(s) 0
                File2 is idle in state(s) 0
                Queue2 is idle in state(s) 0
                Q0 segments left 0, axes/extruders owned 0x0000803
                Code queue 0 is empty
                Code queue 1 is empty
                === CAN ===
                Messages queued 864369, received 1920872, lost 0, boc 0
                Longest wait 3ms for reply type 6053, peak Tx sync delay 277, free buffers 18 (min 17), ts 480201/480200/0
                Tx timeouts 0,0,0,0,0,0
                === Network ===
                Slowest loop: 22.24ms; fastest: 0.00ms
                Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                HTTP sessions: 1 of 8
                = WiFi =
                Interface state: active
                Module is connected to access point
                Firmware version 2.1beta4
                MAC address bc:ff:4d:e6:b1:62
                Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42972
                WiFi IP address 192.168.10.50
                Signal strength -50dBm, channel 1, mode 802.11n, reconnections 0
                Clock register 00002001
                  @Exerqtor that's interesting, it's not the same crash as before but it is the same task (NETW) and probably the same area of code.
                  If your machine is not being used, please can you do a couple of things to increase the load on it, in the hope that this will make the problem occur more frequently. In particular, try these:
                  • In the DWC Machine Specific config, reduce the polling interval e.g. to 100ms
                  • Reduce the lengths of G4 delay commands that you have in daemon.g.
                  Exerqtorundefined 1 Reply Last reply Reply Quote 0
                  • Exerqtorundefined
                    Exerqtor @dc42
                    Guess that's somewhat positive and it would help narrow down the search a little? wishfull thinking
                    Ok I've set the "Communication update invervals" to 100ms now (if that's the one you were refering to).
                    What do you suggest changing the daemon.g delay to? It's currently 1second, so reduce it to 300ms or something maybe?
                      @Exerqtor I suggest you try 100ms. If that makes the response to console commands such as M122 excessively slow, increase it.
                      • Exerqtorundefined
                        Exerqtor @dc42
                        Ok, then both have been set to 100ms. Now it's just to wait for a crash i guess 😅
                        • Exerqtorundefined
                          Exerqtor @dc42
                          Don't look like the added stress we were able to muster up with those changes did much, only had one crash since they were changed:
                          power up + 00:00:08 [warn] HTTP client 192.168.10.100 login succeeded (session key 775616360)
                          2023-06-18 04:59:53 [warn] Date and time set at power up + 00:00:08
                          M122
                          Used output buffers: 1 of 40 (38 max)
                          Static ram: 102996
                          Dynamic ram: 125612 of which 12 recycled
                          Never used RAM 10580, free system stack 180 words
                          Tasks: NETWORK(1,ready,84.6%,219) HEAT(3,nWait,0.1%,327) Move(4,nWait,0.0%,344) CanReceiv(6,nWait,0.2%,672) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,351) TMC(4,nWait,4.9%,108) MAIN(1,running,150.3%,704) IDLE(0,ready,13.1%,29) AIN(4,delaying,3.4%,266), total 256.8%
                          Owned mutexes:
                          Last reset 04:11:46 ago, cause: software
                          Last software reset at 2023-06-18 04:59, reason: HardFault invState, Gcodes spinning, available RAM 9444, slot 2
                          Stack: 000001af 00000002 200014ec 00000000 2003335b 0009d43d 00000000 600f0000 00000000 00000000 00000000 00000000 2003217c 00000800 20035e70 2002c558 20018670 2002c3f5 20018670 2001e920 0002fe6f 00000000 00000000 00000000 20012058 00000014 ffffffff
                          Error status: 0x00
                          Aux0 errors 0,0,0
                          MCU revision 3, ADC conversions started 15106363, completed 15106363, timed out 0, errs 0
                          MCU temperature: min 35.1, current 35.5, max 41.8
                          Heap OK, handles allocated/used 99/32, heap memory allocated/used/recyclable 2048/1372/948, gc cycles 4666
                          Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 63, reads 62550, writes 13, timeouts 0, DMA errors 0, CC errors 0
                          Driver 1: standstill, SG min 2, read errors 0, write errors 1, ifcnt 63, reads 62549, writes 13, timeouts 0, DMA errors 0, CC errors 0
                          Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 166, reads 62549, writes 13, timeouts 0, DMA errors 0, CC errors 0
                          Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 165, reads 62549, writes 13, timeouts 0, DMA errors 0, CC errors 0
                          Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 168, reads 62550, writes 13, timeouts 0, DMA errors 0, CC errors 0
                          Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 54, reads 62553, writes 10, timeouts 0, DMA errors 0, CC errors 0
                          Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 54, reads 62552, writes 10, timeouts 0, DMA errors 0, CC errors 0
                          Date/time: 2023-06-18 09:11:30
                          Slowest loop: 37.72ms; fastest: 0.14ms
                          === Storage ===
                          SD card longest read time 7.0ms, write time 5.6ms, max retries 0
                          === DDARing 0 ===
                          === DDARing 1 ===
                          Daemon is doing "G4 P100        " in state(s) 0 0, running macro
                          === CAN ===
                          Messages queued 135965, received 302172, lost 0, boc 0
                          Longest wait 3ms for reply type 6053, peak Tx sync delay 306, free buffers 18 (min 17), ts 75532/75531/0
                          === Network ===
                          Slowest loop: 22.11ms; fastest: 0.00ms
                          = WiFi =
                          Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42960
                          Signal strength -55dBm, channel 1, mode 802.11n, reconnections 0
                          • Exerqtorundefined
                            Exerqtor @Exerqtor
                            @dc42 Have you had any more time or luck with this David?
                            Mine havent had any news crashes sunday, and been sitting idle since then since it quite frankly ain't stable enough to be used for any duration of time 😂
                              @Exerqtor unfortunately I haven't been able to reproduce it.
                              • Exerqtorundefined
                                Exerqtor @dc42
                                Haven't had any more crashes here either, though the printer has just been sitting idle since last time it happened.
                                  @Exerqtor I'm wondering whether it could possibly be a hardware issue, because I haven't been able to reproduce it and nobody else has reported it. Which country are you in and which Duet3D reseller do you use?
                                  • Exerqtorundefined
                                    Exerqtor @dc42
                                    Might be the case, this perticular board ain't a original duet3 board but a Fysetc "Big Dipper" (killed the processor on my Duet 2 so I needed a subsitute board ASAP, and couldn't justify cashing out for a original duet 3 mini & addon board to the mrs 🤦‍♂️).
                                    It haven't had a single crash since the last one i reportet two weeks ago though. Even with the extra load we added.
                                    Just started a 2.3hr print on it now to see if it wil act up again.
                                      droftarts administrators
                                      @Exerqtor Please be up-front about using clone Duet boards. It would save a lot of time supporting, and trying to resolve issues with, boards who's quality are beyond the scope of what Duet3D can control.
                                      Regarding the Fysetc Big Dipper board, when the TeamGloomy devs took a look at it, they weren't that impressed. When looking at the schematics, it doesn't include as much filtering, and some other corners have been cut, compared to the Duet 3D Mini 5+.
                                        @Exerqtor as I haven't been able to reproduce it, and nobody else has reported it, and it's a clone board, I'll park this issue unless/until someone else reports a similar issue.
                                        The SAME54P20A processor we use in the Duet 3 Mini has been almost impossible to purchase for the last two years, so I wouldn't rule out the possibility that the clone boards use reject/remarked chips.
                                        • Exerqtorundefined
                                          Exerqtor @droftarts
                                          @droftarts It wasn't like I was actively trying to withold any info in that regard. Since it was a non-issue before the specific FW update I didn't even think about it possibly being and HW issue given the circumstances.
                                          I'm in no way doubtfull of the original duets being of way superior quality all across the board, but the circumstances simply didn't allow for it when I had to replace the board i killed.
                                          @dc42 Yeah I haven't had any more issues myself either (knock on wood) so I have no idea what was happening.
                                          And just to be clear, I didn't mean or try to gasslight anyone with not specifying it being a clone board since I assumed it to "simply" being a FW issue introduced to the beta in question.
                                          • Exerqtorundefined
                                            Exerqtor @Exerqtor
                                            @Exerqtor
                                            Just checked the printer and saw it had crashed again, about 30min after the job from yesterday was finished.
                                            Heres the M122 in case it might shine some new light on it 🤷‍♂️
                                            5.7.2023, 18:19:11	M122
                                            Used output buffers: 1 of 40 (28 max)
                                            Static ram: 102996
                                            Tasks: NETWORK(1,ready,1261.8%,211) HEAT(3,nWait,9.0%,327) Move(4,nWait,0.9%,344) CanReceiv(6,nWait,17.5%,672) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,2.8%,351) TMC(4,delaying,423.1%,108) MAIN(1,running,2878.0%,704) IDLE(0,ready,1126.3%,29) AIN(4,delaying,293.3%,266), total 6012.7%
                                            Owned mutexes: WiFi(NETWORK)
                                            Last reset 19:08:33 ago, cause: software
                                            Last software reset at 2023-07-04 23:10, reason: HardFault invState, Gcodes spinning, available RAM 2364, slot 0
                                            Stack: 000001ae 00000002 200014ec 00000000 2003338a 0009d43d 00000000 600f0000 00000000 00000000 00000000 00000000 200321a4 00000800 20035e98 2002c558 20018670 2002c3f5 20018670 2001e920 0002fe6f 00000000 00000000 00000000 20012058 00000014 b5ddc1d1
                                            Error status: 0x00
                                            Aux0 errors 0,0,0
                                            MCU revision 3, ADC conversions started 68913225, completed 68913223, timed out 0, errs 0
                                            MCU temperature: min 34.5, current 35.5, max 41.6
                                            Heap OK, handles allocated/used 99/32, heap memory allocated/used/recyclable 2048/796/372, gc cycles 21269
                                            Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 194, reads 38882, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 194, reads 38882, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 93, reads 38882, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 93, reads 38882, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 92, reads 38882, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 21, reads 38885, writes 10, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 21, reads 38885, writes 10, timeouts 0, DMA errors 0, CC errors 0
                                            Date/time: 2023-07-05 18:19:11
                                            Slowest loop: 37.47ms; fastest: 0.14ms
                                            === Storage ===
                                            SD card longest read time 4.4ms, write time 3.7ms, max retries 0
                                            === DDARing 0 ===
                                            === DDARing 1 ===
                                            === CAN ===
                                            Messages queued 620226, received 1378327, lost 0, boc 0
                                            Longest wait 3ms for reply type 6053, peak Tx sync delay 273, free buffers 18 (min 17), ts 344566/344565/0
                                            === Network ===
                                            Slowest loop: 22.25ms; fastest: 0.00ms
                                            = WiFi =
                                            Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42780
                                            Signal strength -48dBm, channel 1, mode 802.11n, reconnections 0
