    Duet 3 Strange Issues
    duet 3
    • samlogan87undefined
      samlogan87
      Hey Everyone,
      On top of an issue I have been having that I am awaiting help with, I have had another one today twice that have ruined some long prints. The first was a wire got caught for the extruder stepper on the tool board (my fault) however, the print continued even thought it was showing a phase disconnection fault. So I reset it it up this morning and started again. I checked on it 10 hrs into the print again and for some reason, the extruder was showing 2000 degrees, and the print was still going with no faults. I then did a M122 as below and reset the controller, which fixed it. I thought it was maybe the SD card dying so used another one. Went to level the bed again using the 4 corners and the carriage was moving but the bed was not. I am starting to get pretty fed up with the printer as I seem to have no end of issues with it at the moment. Can anyone shed any light on what might be going on. This was the faults that happened when I was not moving the bed.
      5/27/2023, 4:11:29 PM	Connection established
      5/27/2023, 4:11:22 PM	Connection interrupted, attempting to reconnect...
      5/27/2023, 4:10:46 PM	Error: Failed to switch off remote heater 1: Board 20 does not have heater 1
      Emergency Stop! Reset the controller to continue.
      5/27/2023, 4:10:44 PM	Emergency stop, attemping to reconnect...
      5/27/2023, 4:10:42 PM	Error: Board 20 does not have input handle 3000
      5/27/2023, 4:10:38 PM	Error: Board 20 does not have input handle 3000
      5/27/2023, 4:10:35 PM	Error: Board 20 does not have input handle 3000
      5/27/2023, 4:10:31 PM	Error: Board 20 does not have input handle 3000
      5/27/2023, 4:10:27 PM	Error: Board 20 does not have input handle 3000
      There is most defiantly a heater 1.
      And the M122 report from earlier.
      RepRapFirmware for Duet 3 MB6HC version 3.5.0-beta.3 (2023-04-14 11:28:15) running on Duet 3 MB6HC v1.01 (standalone mode)
      Board ID: 08DJM-956BA-NA3TN-6J9FL-3S86L-9TBLT
      Used output buffers: 7 of 40 (40 max)
      Static ram: 154728
      Dynamic ram: 119248 of which 52 recycled
      Never used RAM 68076, free system stack 134 words
      Tasks: NETWORK(ready,28.8%,187) ETHERNET(nWait,0.3%,392) HEAT(nWait,0.2%,324) Move(nWait,9.9%,214) CanReceiv(nWait,0.3%,770) CanSender(nWait,0.1%,327) CanClock(delaying,0.0%,341) TMC(nWait,47.7%,59) MAIN(running,12.5%,137) IDLE(ready,0.1%,30), total 100.0%
      Owned mutexes:
      Last reset 07:42:54 ago, cause: software
      Last software reset at 2023-05-27 08:10, reason: User, Gcodes spinning, available RAM 68016, slot 1
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x04
      Aux0 errors 0,1,0
      MCU temperature: min 34.6, current 39.3, max 40.1
      Supply voltage: min 23.2, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
      Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/520/472, gc cycles 0
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min n/a, mspos 8, reads 41653, writes 11 timeouts 0
      Driver 1: standstill, SG min n/a, mspos 8, reads 41653, writes 11 timeouts 0
      Driver 2: standstill, SG min 0, mspos 936, reads 41639, writes 26 timeouts 0
      Driver 3: standstill, SG min 0, mspos 744, reads 41639, writes 26 timeouts 0
      Driver 4: standstill, SG min 0, mspos 920, reads 41639, writes 26 timeouts 0
      Driver 5: standstill, SG min 0, mspos 664, reads 41639, writes 26 timeouts 0
      Date/time: 2023-05-27 15:53:23
      Slowest loop: 184.14ms; fastest: 0.04ms
      === Storage ===
      Free file entries: 18
      SD card 0 detected, interface speed: 25.0MBytes/sec
      SD card longest read time 3.1ms, write time 7.8ms, max retries 0
      DMs created 125, segments created 43, maxWait 214593ms, bed compensation in use: mesh, comp offset 0.000
      no step interrupt scheduled
      === DDARing 0 ===
      Scheduled moves 310253, completed 310253, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 8], CDDA state -1
      === DDARing 1 ===
      Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
      Heater 0 is on, I-accum = 0.1
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      File2 is idle in state(s) 0
      Queue2 is idle in state(s) 0
      Q0 segments left 0, axes/extruders owned 0x0000000
      Code queue 0 is empty
      Code queue 1 is empty
      === Filament sensors ===
      Extruder 0: no data received
      === CAN ===
      Messages queued 970760, received 1151416, lost 0, boc 0
      Longest wait 3ms for reply type 6053, peak Tx sync delay 452, free buffers 50 (min 41), ts 138874/138873/0
      Tx timeouts 0,0,0,0,0,0
      === Network ===
      Slowest loop: 207.80ms; fastest: 0.03ms
      Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
      HTTP sessions: 1 of 8
      = Ethernet =
      State: active
      Error counts: 0 0 0 1 0 0
      Socket states: 5 2 2 2 2 0 0 0
      === Multicast handler ===
      Responder is inactive, messages received 0, responses 0
      Cheers
      Sam
      Custom Core-XY
        jay_s_uk @samlogan87
        @samlogan87 best post your config and tell us a bit more about your setup
