    Mesh Bed Leveling expected behavior
    443
    • benhaundefined
      benha
      Hi.
      My machine has started misbehaving, and I'm struggling to get good first layers. According to the height map I've generated, there are some low spots and some high spots in my bed.
      I've run G29 S1 to load that map at the beginning of a job, but it doesn't seem like the printer is doing any actual compensation, as I get poor adhesion in the low spots and squeegeed out filament in the highs. (Is there anything else I'm supposed to do to get compensation?)
      Anyway, trying to simplify the debugging I moved between a few points on the plate did a G0z0.51 (equivalent to a 0.020" feeler gauge). I'm not getting consistent gaps between the nozzle and the bed.
      Should the map be applied to a random move like that outside a formal "print"? I would assume so, but we're in uncharted territory here for me.
      Assuming it should, then something's not working right. Any ideas?
      Thanks
      -Ben
        Can you share some additional information?
        It would be good to see the results of sending M122 and M98 P"config.g" in the gcode console tab in DWC. That will tell us your Duet board and firmware version, and show if compensation is active or not, and the M98 will show any syntax errors from your config.g.
        Please also share your full config.g, homing files, bed.g, and your slicer start gcode.
        Additionally, a screenshot of the heightmap display itself.
        And maybe some general details about the printer.
        benhaundefined 1 Reply Last reply Reply Quote 0
        • benhaundefined
          benha @Phaedrux
          @Phaedrux
          Thanks for taking an interest! This is a Railcore ZLT I built several years ago.
          Heat Map:
          Config Files:
          download.zip
          Start gCode:
          ; Railcore 300ZL start code - 20 May 2021
          M140 S[first_layer_bed_temperature] ; Raise bed temp to profile requested bed temp
          M190 S[first_layer_bed_temperature] ; Wait for bed temp to rise
          G28 ; home all axes
          G32 ; Autocalibrate bed
          G32 ; Autocalibrate bed a second time
          G28 Z ; Home Z after bed leveling
          G29 S1 ; Apply mesh bed leveling
          G1 Z20 F600 ; Move bed down 20
          M104 S[first_layer_temperature] T0 ; Raise hot-end temp to profile requested hot-end layer 1 temp
          M109 S[first_layer_temperature] T0 ; Wait for hot-end temp to rise to profile requested hot-end layer 1 temp
          G1 X0.0 Y0.0 Z1.0 F2000.0 ; prepare to prime
          G92 E0 ; reset extrusion distance
          G1 Z0.2 F600
          G1 X60.0 E9.0 F1000.0 ; priming
          G1 X125.0 E12.5 F1000.0 ; priming
          G1 Z0.5 F600
          ; end of start code
          M122:
          M98 P"config.g":
            @benha said in Mesh Bed Leveling expected behavior:
            Config Files:
            download.zip
            You can't upload zip files to the forum. Either copy and paste the contents of the files into a forum post, or upload the files by dragging and dropping them (or copy paste) onto a post window.
            • benhaundefined
              benha @Phaedrux
              @Phaedrux
              Oops! Here they are.
              config.g config-override.g bed.g
                Homing files? 🙂
                • benhaundefined
                  benha @Phaedrux
                  @Phaedrux
                  Ah. Right. Took me a minute to figure out which files you were talking about!
                  homez.g homey.g homex.g homeall.g
                    Phaedrux Moderator @benha
                    So looking at your files now. You are clearing the heightmap at the start of bed.g, doing leveling, loading the heightmap, then repeating that, then running homez.g with the heightmap loaded, and then loading the heightmap again.
                    I suggest you remove the heightmap loading from bed.g and add M561 to your homez.g to clear the heightmap before probing.
                    Then create a fresh mesh with your bed at temp with G28, G32, G28 Z, G29
                    When was the last time you measured your probe offset?
                    I also notice you're using orthagonal axis compensation?
                    ; Orthogonal Axis Compensation
                    M556 S100 X-.25 Y0.198 Z.17
                    How did you come to need this?
                    benhaundefined 2 Replies Last reply Reply Quote 0
                    • benhaundefined
                      benha @Phaedrux
                      @Phaedrux
                      Thank you! Let me mess with this and see if I can get things going correctly. I'm out of town for a few days but I'll revert back when I've tested it.
                      The Orth. Axis Comp. eval / tuning was something the Railcore setup guide recommended. Intuitively it makes sense that you're not going to have perfect perpendicularity between the X and Y axis mechanicals, right? I mostly print engineering parts so getting things to print angles in the x-y plane as correctly as possible is important to me.
                      • benhaundefined
                        benha @Phaedrux
                        @Phaedrux
                        Ok. Made these changes and I'm still having issues.
                        As you can see in the attached image, the layer deposition in the back corner of the plate is poor. To my eye it seems the only explanation is that the gap between the nozzle and the bed is widening, resulting in poor bed adhesion, and also gaps between the filament lines.
                        When I remove this from the plate, I see some areas where things are fully fused into a sheet, and others where they're not. Again, the only thing I can think of to explain this is that in bed areas which are closer to the nozzle as it prints there's more squeeze forcing things together, and in other areas the nozzle is further away resulting in this issue.
                        Thoughts?
                          Can you test the probe trigger height at a few different points on the bed and see if it's consistent?
                          https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing#calibrate-the-z-probe-trigger-height
