Disable stealth chop
hello,
I just read that for the Orbiter 2.0 I have to disable stealth chop.
How can I do it?Thanks
Richard -
https://docs.duet3d.com/en/User_manual/Connecting_hardware/Motors_tuning#tuning-the-stepper-drivers
You'd want to put it in spreadcycle mode.
@IndeX4D if you run RepRapFirmware 3.4.0 or later than the drivers will be in spreadCycle mode by default.
You can check which mode a driver is in my sending M569 P# where # is the driver number.
hey
thanks for your fast answer.there is just written ´´´drive motor with stealth chop disabled´´.
rrf 3.5 beta 3
My extrudr stops midprint, but it´s not clocked or something. When I pause print everything is fine.
But extruding while printing is only possible again after restart.
I´ve read a very old posting. Let me take a look for it, but before I wanted to be sure, that stealth chop is disabled. -
https://forum.duet3d.com/topic/3483/extruder-motor-stops-during-print/91
I think I´ve the same but first try to ground the nozzle has not helped.
@IndeX4D this is a known issue and fixed in 3.5b4 that due to be released soon
@jay_s_uk ah really?
Has not happened a lot of times. Now, every print. So... that sounds for a short vacation. When will beta 4 available? -
@IndeX4D "soon". I believe it's imminent
@jay_s_uk
Okaay
Thanks
