    Hello
    • ddtunderundefined
      ddtunder
      Can somebody help me with driver and software for st3di pro280.
      I got this printer but without software and driver.
        Does it have a Duet board in it?
          droftarts administrators @ddtunder
          @ddtunder The ST3DI website seems to have disappeared (last active in 2019), but you can see it in the Wayback Machine: http://web.archive.org/web/20190726203455/http://www.st3di.com/
          There's some ST3DI produced videos on this youtube channel https://www.youtube.com/@st3di3dprintersandconsumab53/videos though all the videos are from 7 years ago.
          From what I can see, it does not run a Duet board. I'd expect it to be connected to Ethernet and use the web interface if it did, but it looks like everything runs from a built-in screen. Looking at the pictures in the thread below, it looks like a custom RAMPS board, probably using a ATMEGA 1240 or 2560, running a customised version of Marlin. So not something we support on this forum.
          There's a long thread in the forum here https://forum.duet3d.com/topic/20707/st3di-modelsmart-280-duet-maestro-repair-upgrade/ about user @Blacksheep99 converting one to use a Duet Maestro. A Duet 3 Mini 5+ would be a better board to use now. There's also a link at the end of that thread to some of the original ST3DI files.
          I'm moving this thread to 'General', not really relevant in 'CNC'.
          Blacksheep99undefined 1 Reply Last reply Reply Quote 0
          • droftartsundefined droftarts moved this topic from CNC
          • Blacksheep99undefined
            Blacksheep99 @droftarts
            @droftarts @ddtunder
            Here is the original slicing software https://drive.google.com/file/d/1f1yuOidiOxlcGvqfJhKm9rftpKGLOB2k/view?usp=drive_link
            It's old and clunky. You can use a slicer like Cura or Prusasclier with the printer with a little bit of work. If you want to update the printer then as @droftarts says look at one of the current duet boards.
            If I can help let me know, I'll try asisst.
            ddtunderundefined 1 Reply Last reply Reply Quote 2
            • ddtunderundefined
              ddtunder @Blacksheep99
              @Blacksheep99
              thanks man, it's work perfect, my son try program and all is 👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍👍
