3.5.0-B3 Reboot in Laser mode
Hi, with new beta update I have problem in laser mode. When I try home axis or move axis from DWC Duet2 Wifi (Standalone) reboot itself.
Commands like G0 X10 works normaly, but G28 in console -> reboot.
FW 3.4.5 works good. -
@cichaczech post an output of M122 after the reboot
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.0-beta.3 (2023-04-14 11:27:37) running on Duet WiFi 1.02 or later Board ID: 0JD0M-9P6M2-NW4SS-6JKDD-3S86R-KAZ7L Used output buffers: 1 of 26 (15 max) === RTOS === Static ram: 22192 Dynamic ram: 74716 of which 244 recycled Never used RAM 15992, free system stack 184 words Tasks: NETWORK(nWait,11.0%,238) HEAT(nWait,0.0%,386) Move(nWait,0.0%,364) MAIN(running,80.9%,559) IDLE(ready,8.1%,29), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:00:11 ago, cause: software Last software reset at 2023-06-09 12:21, reason: HardFault bfarValid precise, Gcodes spinning, available RAM 15492, slot 2 Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x0041f803 BFAR 0x6b4bd9b0 SP 0x20003b38 Task Move Freestk 379 ok Stack: 20008908 00000001 00000270 6b4bd450 a5a5a5a5 0042a6e3 0043cee0 a1000000 00000000 00000000 00000000 00000000 3f800000 00000000 00000000 00000000 2000bcf8 00000000 00000001 2000bcfc 2000487c 00000000 00000000 a5a5a5a5 0042a6e3 a5a5a5a5 a5a5a5a5 Error status: 0x00 Aux0 errors 0,0,19 MCU temperature: min 23.8, current 24.1, max 24.4 Supply voltage: min 23.6, current 23.7, max 23.8, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min n/a Driver 1: standstill, SG min n/a Driver 2: standstill, SG min n/a Driver 3: standstill, SG min n/a Driver 4: standstill, SG min n/a Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: Date/time: 2023-06-09 12:21:49 Cache data hit count 418033720 Slowest loop: 8.31ms; fastest: 0.19ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 12.0MBytes/sec SD card longest read time 1.0ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 no step interrupt scheduled === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is assembling a command in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Q0 segments left 0 Code queue 0 is empty === Filament sensors === Extruder 0 sensor: ok === Network === Slowest loop: 111.47ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 = WiFi = Network state is active Module is connected to access point Failed messages: pending 0, notready 0, noresp 0 Firmware version 1.27 MAC address bc:ff:4d:45:e0:c1 Module reset reason: Power up, Vcc 3.39, flash size 4194304, free heap 27176 WiFi IP address 10.0.0.120 Signal strength -59dBm, channel 0, mode 802.11n, reconnections 0 Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0 -
@cichaczech as we're in the process of releasing 3.5.0-beta4 please can you test it again using that release and report back. If it happens in beta4 then please post a M122 report after the reset again.
@dc42 Ok, will do.
Thank you. -
@dc42 still the same
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.0-beta.4 (2023-06-08 23:39:39) running on Duet WiFi 1.02 or later Board ID: 0JD0M-9P6M2-NW4SS-6JKDD-3S86R-KAZ7L Used output buffers: 1 of 26 (15 max) === RTOS === Static ram: 23236 Dynamic ram: 74836 of which 244 recycled Never used RAM 14828, free system stack 184 words Tasks: NETWORK(2,nWait,12.2%,238) HEAT(3,nWait,0.0%,385) Move(4,nWait,0.0%,364) MAIN(1,running,81.7%,819) IDLE(0,ready,6.1%,29), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:00:15 ago, cause: software Last software reset at 2023-06-09 17:27, reason: HardFault bfarValid precise, Gcodes spinning, available RAM 14328, slot 0 Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x0041f803 BFAR 0x6b4bddd0 SP 0x20003f60 Task Move Freestk 379 ok Stack: 20008d28 00000001 00000270 6b4bd870 a5a5a5a5 004291c3 0043c218 a1000000 00000000 00000000 00000000 00000000 3f800000 00000000 00000000 00000000 2000c168 00000000 00000001 2000c16c 20004bb4 00000000 00000000 a5a5a5a5 004291c3 a5a5a5a5 a5a5a5a5 Error status: 0x00 Aux0 errors 0,0,18 MCU temperature: min 22.9, current 23.5, max 23.6 Supply voltage: min 23.6, current 23.7, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min n/a Driver 1: standstill, SG min n/a Driver 2: standstill, SG min n/a Driver 3: standstill, SG min n/a Driver 4: standstill, SG min n/a Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: Date/time: 2023-06-09 17:28:13 Cache data hit count 558914657 Slowest loop: 8.27ms; fastest: 0.19ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 12.0MBytes/sec SD card longest read time 1.0ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is assembling a command in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Q0 segments left 0 Code queue 0 is empty === Filament sensors === Extruder 0 sensor: ok === Network === Slowest loop: 111.94ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 = WiFi = Interface state: active Module is connected to access point Failed messages: pending 0, notready 0, noresp 0 Firmware version 1.27 MAC address bc:ff:4d:45:e0:c1 Module reset reason: Power up, Vcc 3.39, flash size 4194304, free heap 27096 WiFi IP address 10.0.0.120 Signal strength -59dBm, channel 0, mode 802.11n, reconnections 0 Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0 -
@cichaczech please try again. The stack trace in your M122 report doesn't match the 3.4.0-beta.4 code, so I suspect you were running different firmware when that last reset happened.
@dc42 Today I tried delete old FW and instal beta4 with BOSSA, but it still keeps rebooting when I try to home it.
For now I am moving back to last stable releasethis is my latest M122
=== Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.0-beta.4 (2023-06-08 23:39:39) running on Duet WiFi 1.02 or later Board ID: 0JD0M-9P6M2-NW4SS-6JKDD-3S86R-KAZ7L Used output buffers: 13 of 26 (20 max) === RTOS === Static ram: 23236 Dynamic ram: 74836 of which 244 recycled Never used RAM 14828, free system stack 186 words Tasks: NETWORK(2,nWait,12.5%,238) HEAT(3,nWait,0.0%,383) Move(4,nWait,0.0%,364) MAIN(1,running,78.8%,819) IDLE(0,ready,8.7%,29), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:00:10 ago, cause: software Last software reset at 2023-06-12 09:11, reason: HardFault bfarValid precise, Gcodes spinning, available RAM 14328, slot 2 Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x0041f803 BFAR 0x6b4bddd0 SP 0x20003f60 Task Move Freestk 379 ok Stack: 20008d28 00000001 00000270 6b4bd870 a5a5a5a5 004291c3 0043c218 a1000000 00000000 00000000 00000000 00000000 3f800000 00000000 00000000 00000000 2000c168 00000000 00000001 2000c16c 20004bb4 00000000 00000000 a5a5a5a5 004291c3 a5a5a5a5 a5a5a5a5 Error status: 0x00 Aux0 errors 0,0,18 MCU temperature: min 22.2, current 22.7, max 23.0 Supply voltage: min 23.7, current 23.7, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min n/a Driver 1: standstill, SG min n/a Driver 2: standstill, SG min n/a Driver 3: standstill, SG min n/a Driver 4: standstill, SG min n/a Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: Date/time: 2023-06-12 09:11:56 Cache data hit count 397729243 Slowest loop: 9.39ms; fastest: 0.19ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 12.0MBytes/sec SD card longest read time 1.0ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is assembling a command in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Q0 segments left 0 Code queue 0 is empty === Filament sensors === Extruder 0 sensor: ok === Network === Slowest loop: 114.56ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(2) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 3 of 8 = WiFi = Interface state: active Module is connected to access point Failed messages: pending 0, notready 0, noresp 0 Firmware version 2.1beta3 MAC address bc:ff:4d:45:e0:c1 Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 38084 WiFi IP address 10.0.0.120 Signal strength -54dBm, channel 1, mode 802.11n, reconnections 0 Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0 -
@cichaczech please can you provide your config.g and homing files, so that I can try to reproduce this.
@cichaczech I haven't managed to reproduce the problem, but I believe I have identified the issue. It's specific to laser mode. Please try the Duet 2 firmware binary at https://www.dropbox.com/sh/c4aatfdsejjjab0/AACGuZ4qUBvZz49zxErkhmnWa?dl=0 and see if it resolves the problem.
I think a workaround for this issue using the original 3.5.0-beta4 firmware binary would be to issue a G1 move with an S parameter after switching to laser mode with M452 but before doing the very first real move (i.e. before homing). Even G1 S0 with no other parameters should be sufficient.
@dc42 Both of your solutions work.
3.5.0-beta4 -> you have to send G1 S0 after switching laser mode
3.5.0-beta4+ -> works normally in laser mode, without any additional commandsThank you.
@cichaczech thanks for confirmation! The fix will be included in 3.5.0-rc.1. I'll mark the Github issue I created at https://github.com/Duet3D/RepRapFirmware/issues/869 solved.
